Thread: 80 mm tb
Results 1 to 5 of 5
  1. #1 80 mm tb
    SE Level Member fever42's Avatar
    May 2008
    Mobile, Al
    80 mm Throttle body assy has anyone ever used this on a mod L67 setup or is it too much have a 72 on there now can get cheaper than a northstar Thanks
  2. #2 Re: 80 mm tb
    Kemmerer, Wyoming
    ZZP used to have an 87mm throttle body kit, they haven't made it for a long time though. If you do an 80mm, you will have to port the inlet of the supercharger to match, or it won't help much. I say go for it, more air in, more power.
  3. #3 Re: 80 mm tb
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    If you can open the supercharger inlet, as mentioned, having the biggest TB you can get is best. I've got a 102mm LSx waiting to go on my MP112 when that gets put into something in the future (original INTENSE/ZZP kit from 2003 has regular 75mm LS1 TB adapted).
  4. #4 Re: 80 mm tb
    May 2008
    Mobile, Al
    Love it makes a lot of torque , litte McGavier to get all hooked up it was from a Ram 5.7
  5. #5 Re: 80 mm tb
    SE Level Member GTP Mark's Avatar
    Dec 2019
    Canada
    Post pics if you get that 80mm on there.
    ZZP used to make a 78mm throttle body. Looked like a stock L67 TB, but was larger. That was over 10 years ago now I think. I have seen people make a larger aftermarket LS cable style TB work.
    I am actually having a local machine shop port a extra Northstar TB I have. Should be able to get it to 78mm. Will need to make a larger throttle blade though. Going to port the inlet of a Gen V to match.
