Thread: What size pulley and what size belt??
Results 1 to 5 of 5
  1. #1 What size pulley and what size belt??
    GTP Level Member David99GTP's Avatar
    Florida
    Ok not the typical pulley question newbies ask all the time LOL
    I bought an electric water pump. Intense says use a 4" smaller belt. My issue is while I am installing this pump I am buying a pully also. What size pulley can I go down to safely and how do I know what size belt to get?
    Mods Borla exhaust, SLP headers (installing next month) Wizaired CAI, DHP PCM, 42.5lb injectors, PRJ gen III fuel rails, MSD coil packs, 10.4mm wires.
    As always thanks in advance!!!!
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  2. #2 Re: What size pulley and what size belt??
    Barksdale AFB, LA
    You mean you're installing a SC pulley? That's a different belt than the one that runs the water pump (the accessory belt).
    The only smart way to pulley down is scan, down the pulley, scan, down the pulley, etc.
    2009 Subaru Impreza WRX STI
  3. #3 Re: What size pulley and what size belt??
    Charles City, IA
    x2 on scanning. I would. Think the shorter belt is to get it to stock tension. U should be able to run a 3.5 pulley.
    SMGPFC Two Nipple General
  4. #4 Re: What size pulley and what size belt??
    Apr 2008
    Chillin at the Beach , VA
    I don't see why you couldn't get down to a 3.4. Are you going with the MPS set up? Can order with the 3.4, scan, and if need be, go back to the 3.5.
  5. #5 Re: What size pulley and what size belt??
    Florida
    I went an ordered the 3.5 pulley for the belt tensioner so I can run the 3.4 pulley and use same belt size. With the electric water pump I realized it is a 4" shorter belt
    1999 GTP
  1. Boosting Pulley size
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2008, 05:07 PM
  2. Which pulley size will work with my car?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-17-2008, 12:18 AM
  3. pully size? (not the sc pulley)
    By SlowPurpleGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2008, 08:39 PM
  4. stock size? PLEASE HELP on piping and 2.25 muffler size
    Last Post: 07-27-2008, 09:52 PM
  5. pulley size=hp?
    By underpressure2004 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2008, 11:03 PM
