Thread: Need help resolving this code........
Results 1 to 9 of 9
  1. #1 Need help resolving this code........
    Aug 2008
    SOUTH TEXAS
    About month and a half ago.
    I replaced my front 02 sensor, because the ses light would come on.
    The car would throw a p1133 code.
    This morning the ses light came on again,same code p1133.
    I have ruled out that it the sensor since its almost new.
    (P1133 HO2S insufficient switching sensor 1)
    What now?
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  2. #2 Re: Need help resolving this code........
    Aug 2008
    SOUTH TEXAS
    Found this:
    So knowing all of this what should we check when we have those pesky rich or lean codes? The most common issues for lean codes are:
    1. Vacuum leaks - check for failed or loose vacuum lines, leaking intake gaskets, intake air tubes loose or any other source of un-metered air leaks (leaks after the Mass Air Flow Sensor)
    2. Restricted fuel filter or bent/pinched fuel system lines
    3. Incorrect input from other sensors, such as the Mass Air Flow Sensor, which may not always drop a separate code
    4. Engine misfire – Yes I know this one may seem weird. You might think that if there is a misfire then you will have all that unburned fuel and it should read rich; right? Well the O2 sensors read only oxygen content in the exhaust, so if you have all that unburned fuel from incomplete combustion then, you guessed it, you also have all that unburned oxygen. High O2 content in exhaust equals a lean reading!
    There are also some other possibilities such as an internally leaking EGR system, (but this will typically set a separate code). A leak in the exhaust system before the O2 sensor will also cause incorrect readings. And always check for after- market modifications. These can throw a wrench into the works! The only other possibilities (however unlikely), are wiring issues, computer concerns or a bad O2 sensor! There now that I’ve said it, on to rich codes.
    The possible causes of rich codes are:
    1. A leaking or faulty fuel injector
    2. Fuel injector driver in computer shorted, or wiring short for injectors (likely a ground short)
    3. Leaking or faulty fuel pressure regulator or restricted return line
    4. Faulty evaporative emissions system - bleeding fuel vapors into engine (not commanded by computer)
    5. On newer models a faulty fuel pump or fuel pump driver module
    6. Faulty readings from other sensors such as a Mass Air Flow Sensor. You may actually be getting more air than the MAF tells the computer
    7. Exhaust leaks before the sensor will cause erratic readings
    8. After market components or performance chips
    9. And yes, if I dare say it, possibly a computer, wiring issue or even a faulty O2 sensor!
  3. #3 Re: Need help resolving this code........
    usually insufficient switching is the o2 sensor itself, but you said it was new..
  4. #4 Re: Need help resolving this code........
    Aug 2008
    SOUTH TEXAS
    I got no extension harness on the car.
    I was able to get it to reach the plug.
    Its a zz p racing version 02.
    The thing about it, is that if i went WOT couple of times with the previous 02 sensor the ses light would turn off.
    But then i replaced it still, thinking it was the problem.
    Havent tried it with this one yet, cause i just rebuilt this motor.
  5. #5 Re: Need help resolving this code........
    SES lights would be the least of my worries with a new motor. i would be watching oil pressure and coolant temperature a lot closer than anything else.
  6. #6 Re: Need help resolving this code........
    Aug 2008
    SOUTH TEXAS
    True that!
    But i'm very picky with my car and keeping things working right.
    Thanx for all the help!
  7. #7 Re: Need help resolving this code........
    Aug 2008
    SOUTH TEXAS
    This morning coming to work i went Wot from 60mph.
    And the ses light turned off.
    On my previous 02 sensor it would do the same thing.
    What do you guys think?
    Anybody had this code(Problem before)?
  8. #8 Re: Need help resolving this code........
  9. #9 Re: Need help resolving this code........
    Aug 2008
    SOUTH TEXAS
    did it come back on when you were driving normally?
    Nope!
    Not yet at least.
    Need to drive some more, c what happens.
  1. I got a code!!!???
    By justwhisen in forum General Tech Discussion
    Last Post: 04-14-2010, 07:22 PM
  2. code...
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 12:22 AM
  3. I need a bit of help with a trans code
    By 4dr2000gt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-15-2008, 11:03 PM
  4. Anyone know a paint code?
    By Reptile in forum Off Topic Discussion
    Last Post: 08-12-2008, 03:30 PM
  5. Paint Code help
    By Quicksilver_GP in forum Visual/Body Modifications
    Last Post: 03-18-2008, 08:37 AM
