Thread: Is my belt slipping
Results 1 to 8 of 8
  1. #1 Is my belt slipping
    Apr 2015
    Columbus, OH
    picture host ru
    There is some residue on the side of the overflow tank. And the MAP and calculated boost fluctuate a little on a wot pull, while my MAF steady climbs. Just looking for confirmation before I buy a belt from someone who's experienced this before. I'm running a 3 inch pulley and current belt is
    653 - GTP/GS/SS supercharged with 3.1 - 3.5" pulley (65 7/8")
    Should I drop to a 65 1/2"? That's the next size down but it's only 1/4" difference.
    Top Swapped 01 Imp
  2. #2 Re: Is my belt slipping
    Apr 2015
    Columbus, OH
    Sorry, formating got me again. Current belt is 65 7/8 from zzp.
    Is there a good replacement I can get from advanced Auto or somewhere local? I've been searching for awhile but haven't found it yet.
    Top Swapped 01 Imp
  3. #3 Re: Is my belt slipping
    those dots of some type of fluid are from a coolant or axle leaking grease, belt catches it and slings it. could even have a stripe under the hood.
  4. #4 Re: Is my belt slipping
    Apr 2015
    Columbus, OH
    Only thing leaking is oil pan. Slow leak. I put a smaller belt on it anyways.
    Looking at one of your scans what does the MAP do at 100% throttle? I really haven't paid much attention to it because I had a 1 bar sensor on. I put the 2 bar just to see boost. I hit 14psi. But it kinda fluctuates up and down even though rpms are steadily increasing. Maybe it's normal, dunno.
    Top Swapped 01 Imp
  5. #5 Re: Is my belt slipping
    you need to change a map setting or two when you swap the map out. best to get a sc file for your car and compare it with your tune.
  6. #6 Re: Is my belt slipping
    Apr 2015
    Columbus, OH
    Sloppy Mechanics Wiki - GM Map Sensor Identification - scale - offset - settings
    Yup. I've been using sloppy's values for awhile. Even if the values were off a bit it shouldn't matter when it comes to fluctuating values at wot. It's probably just the nature of the m90. Also may be because I'm near the limit of a 2 bar map. I'd like to see someone else's scan, hint hint. It's all in fun, for education.
    Top Swapped 01 Imp
  7. #7 Re: Is my belt slipping
    Oct 2014
    portland oregon
    Like This? lol
    Sent from my SM-N920V using Tapatalk
  8. #8 Re: Is my belt slipping
    Apr 2015
    Columbus, OH
    Nice chit stains! I pulled the hood insulation/whatever off a few weeks ago. No farts stains here. 😆
    Top Swapped 01 Imp
  1. Alternator belt...$5 Damaged caused by belt...Priceless
    By sugaryuk in forum Off Topic Discussion
    Last Post: 06-30-2015, 11:41 PM
  2. MPS slipping?
    By J57ltr in forum General Tech Discussion
    Last Post: 06-12-2015, 02:57 PM
  3. Size wrench needed to adjust belt tensioner for accessory belt install?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2011, 09:29 PM
  4. slipping?
    By GMPUNK in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-19-2011, 06:35 AM
  5. Supercharger belt slipping?
    By starscream5000 in forum General Tech Discussion
    Last Post: 10-25-2010, 07:57 PM
