Thread: Planning my mods, need advice
Page 8 of 14 FirstFirst ... 678910 ... LastLast
Results 141 to 160 of 272
  1. #141 Re: Planning my mods, need advice
    Apr 2015
    Columbus, OH
    I have the AEM e85 pump. I can run it pretty low because I've hacked out the bottom of the canister. I had 3 or 4 pumps that all failed since I went e85. The AEM has been in the longest. So much for those who say the stock pumps won't have an issue with e85.
    Still, I try not to let the fuel get below 1/4. It's just good practice for several reasons. Plus, filling up with e85 is so "cheap" I almost look forward to topping it off.
  2. #142 Re: Planning my mods, need advice
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Got the pump installed and the hoses routed for the most part. I am waiting to install the belts before i do the final trim. Pop made a standoff bracket for the pump, where its supposed to mount where the horns were. It let us mount the pump vertically, and its not rubbing against anything. it also made connecting the wires easier. I also cut some of the headlight opening, the part close to the radiator at the bottom. This should make it easier to route the hoses. We shoved the horns into the fender. I will post some pics later.
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  3. #143 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by bandook View Post
    Good to know, now i dont feel bad about spending the extra 20 bucks.
  4. #144 Re: Planning my mods, need advice
    Jul 2017
    macomb mi
    oh yea its definitely worth spending the extra bucks I feel like crap for not spending the extra $20 then having the buy the whole pump plus the extra $20 only months later In a pinch
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  5. #145 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Ok, I am more than a bit late with photos, but check out the link below for what i have going on.
    Update your browser to use Google Drive - Google Drive Help
    1st we got the fuel rail situation sorted out. We used some steel line, and compression fittings to modify the stock rail. The front line around the SC snout is temporary, it will be replaced with some braided line when Im not trying to just get the car to run again. I checked the hood clearance and all seemed well.
    2nd. My pop mad a stand off bracket for the IC pump so that its not wedged in place, and so that it can stand up and down.
    3rd, you can see that the headlight opening was expanded, we cut and folded down some metal to give the hoses more clearance.
    Interestingly, the injector wires on the back side of the engine wont reach. Tuesday, pop is going to extend them.
    Pop is also going to make a T bracket to fit between the fender and the belts to hold the hoses in place to prevent any chance of them rubbing.
    To do:
    1. Wire everything back up, including lengthening the rear injector harnesses
    2. Change the oil and add coolant
    3. add fluid to and purge the IC
    4. reinstall the front bumper.
    5 Flash the ECU for the new injectors
    Hoping to have the thing up and running thursday night.
    Oh yeah, still no answer from ZZP on how to install their fuel logs, so come tuesday im requesting a refund.
  6. #146 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Got the belts on, plugged up most of the wires, and started adding fluid to the IC.
    How do i tell when the IC is completely primed?
    Also, How did you all route your hoses through the SC belts. they are super close and it seems like hitting a pothole would be enough to make them shift and rub.
  7. #147 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    20150916_113354.jpg - Google Drive
    this is how I had mine routed, if I was going to redo it, I would probably use a more solid hose because I did have a minor kink in one of the lines
  8. #148 Re: Planning my mods, need advice
    if your tubes dont allow you to turn the hoses over the coils, you can add 90º elbows to turn em. ive never been a fan of running the hoses through the belts.
    got mine ran through the hole behind the head light.
    as far as filling the ic and core. it depends on if you have a res tank, or just a fill tube or a rad cap not knowing what fmhe you have. fill the system pump off, then pump on keep filling it till it takes no more if on the hose fill or rad with cap. with a res tank you can see it spit air out and know for sure its all bled out.
  9. #149 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    I have the style with the filler tube. Problem, im not sure how to tell if some of the air in my highest hose section has been able to be pushed out
  10. #150 Re: Planning my mods, need advice
    make end of tube higher then the ic core keep filling till it takes no more
  11. #151 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Saturday Was an absolute chore. We got the fuel rail to stop leaking, but starting the car didnt go well. it wsa running insanely rich, and wouldnt idle. Were talking -80% fuel trims.. We also found out the MAF sesnor wasnt working. (i think it failed during the SC porting. I tried adjusting the fueling, we checked the thing up and down, i even removed the 80lb injectors and put the stock ones bakc on and same issue. Finally, i had pop remove the vacuum line from the Fuel pressure regulator. no vacuum from the line. So the car was in Speed density mode, and not only was the regulator flowing crazy, but the MAP sensor wasnt getting vacuum either. What happened is that the T fitting that connects to the front of the LIM collapsed. Once I replaced it the car ran fine.
    No fuel leaks, no knocking etc. The big issue is the MAF sensor is still trashed.
    Im hoping to drive it home tonight. Its still runing rich around 12% but I think thats more so needing to be tuned for all of the new stuff. ZZP is sending me 300 bucks in store credit, so i plan to get a front powerlog, whcih will support a turbo build.
  12. #152 Re: Planning my mods, need advice
    damn 2 dollar parts fuking the works up.
  13. #153 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    a powerlog will only help you if you get the stattama turbo kit. the other kit is designed to be run off of oem exhaust manifolds and cartuning is designed to be run off oem manifolds too.
  14. #154 Re: Planning my mods, need advice
    Antioch, IL
    Cartuning and plog ran here........ Its a oem'd header.......
    2009 Challenger SRT8
    Expert at being gay.
  15. #155 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    oh duh, not sure why I forgot that
  16. #156 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Well, i drove her home last night. Drove it to work today. I currently have a fire extinguisher in the car, because i dont fully trust the fuel rail yet.
    Otherwise the car is running pretty well. It is running lean but the LTFT hasnt sorted itself out yet. I did get on the car a bit and no KR. I am not sure if I am seeing the boost i am supposed to be seeing.
    I saw about 11PSI of boost on a 2.9 inch pulley. I have the stock exhaust manifolds. ported SC outlet, the IC, and the adjusted ratio rockers, also a 3 inch DP. Is this what i should expect? I did loose the coating on my rotors.
  17. #157 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    That sounds about right to me.
    You should use that $300 on a fuel rail so your car doesn't burn to the ground.
  18. #158 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    I had the fuel rail, thats what i sent back.
  19. #159 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Yeah I saw that. I'm not sure why though. Now you have a rail that can leak.
  20. #160 Re: Planning my mods, need advice
    Jul 2017
    macomb mi
    if I read right I seen you had the fuel logs and took them back because they were not bolt on and needed modifications to work this is understandable. fuel logs are pretty overkill for the build I just went with modified rails from zzp never really heard any issues and they are a direct replacement only I would recommend getting these as they are half the price of the logs as well
  1. New guy advice for mods
    By Cory2236 in forum Introductions/Noob Questions
    Last Post: 04-02-2017, 02:16 PM
  2. Planning next MODS.
    By rickisrad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2017, 07:29 AM
  3. what do you think? need some advice on mods.
    By gtpeddie in forum General Grand Prix Discussion
    Last Post: 06-10-2012, 12:07 PM
  4. some advice on my mods?
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 02:16 PM
  5. Mod advice from those w/o mods
    By IndeedSS in forum The Rant Forum
    Last Post: 03-09-2008, 08:26 PM
