Thread: Planning my mods, need advice
Page 1 of 14 12311 ... LastLast
Results 1 to 20 of 272
  1. #1 Planning my mods, need advice
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Hi all,
    I am working on planning my next stage in mods. For the moment I have a DP, 180* tstat, Hp tuners a K&N drop in, and soon e85. (on the engine anyway)
    I want to go big with my next set of mods and the direction I take will determine my modding path forward.
    Option 1, is an intercooler, injectors, and headers.
    Future: porting a N* TB, and Rockers. maybe Methanol
    Option 2. is to do the ZZP z3 turbo kit (or get one for sale somewhere on the forums)
    I would probably make a custom intercooling setup, I have some Intercoolers laying around from swaps on other cars anyway.
    I would run the turbo with e85 (on bigger injectors
    Future: rockers a TB, maybe methanol.
    My bottom line goal is 300whp on a Dynojet more is better of course.
    I Know that the turbo is the move for real power, but can i get close to my power figures by using e85 and an intercooler?
    If i run 60# injectors, e85, an intercooler and turbo, what kind of HP would i be expecting?
    Same questions with the m90
    I can do everything on the list for the m90 for about 1300 bucks
    The turbo would run me 2900 assuming i buy new.
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    I suppose another option would be to run Methanol instead of the intercooler. That way I could still use it with the turbo, but get similar gains.
  3. #3 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    you could do what scott did and run an intercooler with water/methanol. with E85, I bet you would be close to 350 hp at the wheels.
  4. #4 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by SgtMarshal View Post
    What kind of pulley does that throw me down to? like a 2.6?
  5. #5 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    I wouldn't go smaller than a 2.8 on a gen 3, diminishing returns ya know. scott ported his heads and did rockers, and upgraded to a gen 5 with a N* tb and LQ4 maf.
  6. #6 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Sounds like at that point im nearing the price of a turbo kit. (with the Gen 5, IC, and porting)
    I wonder what kind of power i can make with E85, and meth on a turbo.
  7. #7 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    he did the porting himself, will save a lot of money
  8. #8 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    also , dumb question, but headers are going to be come a neccessity for me soon right? even if the Meth and E85 can keep everything cool?
  9. #9 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    a new intercooler costs about 1000 and will make about 50 hp, a water/methanol kit will cost about 500 and will make about 20 hp, E85 is cheap, 60 lb injectors will run about 250 and will support about 50 hp. rockers are about 450 and will make like 20 hp. so there's 2100 dollars a good amount of hp at the wheels. you will need some transmission work with that combo, and will with the turbo as well, so consider that as well.
  10. #10 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Yeah I totally get that the trans is going to blow. Im keeping that tally seperate from here. I thought meth allowd about a .5 pulley drop. My plan is to run 80lbs since im doing e85.
  11. #11 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    some people argue that headers are not necessary, you might be ok with just a downpipe. I run headers, but I've seen convincing arguments for and against headers.
  12. #12 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    if you stick with the m90 you won't need 80's
  13. #13 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    If i run the e85, and the intercooler, and some rockers, seems like i could see 300whp pretty realistically?
  14. #14 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    I would imagine
  15. #15 Re: Planning my mods, need advice
    Quote Originally Posted by 04lss View Post
    meth let me go from a 3.2 on 93 gas, rockers 42 injectors, ported heads, fsic, added meth, dropped to a 2.8 and 21º wot timing. up from 14.
    since the gen 5 and n* swap i just did, my injectors maxed out on the 2.8 with gen 5, so i had to pulley up to a 3.0, since that blower swap my car feels every bit of 300 hp now. traction is like not there at all. and i make the same boost. 13 ish. the 2.8 made 15 at 5300 rpm on the gen 5. i had to let off i was still tuning in my maf. but the scan showed the injectors were over 100%....bummer, if i got 60 lb injectors i bet i could go 2.7 or 2.6 easy.
  16. #16 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Ok,
    here is where i have landed, (with a few questions thrown in)
    ZZP FSIC 800
    Modified fuel rail (scotty's method) 50
    Injecotrs (is there any reason i shouldnt run 80s instead of 60s?) 250
    zzp 1.9 rockers (should i go with someone elses? 300
    90lb springs and retainers 100
    Headers 180
    wideband o2 200
    Fuel pump(do i need a fuel pump for this?) 150
    3.0(?) pully
    e85 ... yes
    Maybe:
    Porting the LIM and SC myself
    Meth 350
  17. #17 Re: Planning my mods, need advice
    Jul 2017
    macomb mi
    that's pretty much my exact setup once I install the intercooler except ill have a ssic and I have 1.95 rockers a fuel pump is required even without the intercooler I needed an upgraded pump to get the full benefit of the rockers and people said #60 injectors on my setup was overkill so im sure they will be just fine plus ive seen some where bigger injectors create less mist or something and if youre not using pushing them then they can create less hp then if you were to use a size that would more appropriate just something I heard and #60s are a tad cheaper so I didn't argue haha also im on a 3.1 pulley without the intercooler with your full size intercooler I feel you could run a 2.8? or just run a ton of timing with 3.0
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  18. #18 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by tzerilli View Post
    Maybe i get the injectors first, and see what i can run on e85. Or start with a 3.0 and if its all good drop to a 2.8. I know Scotty had issues on his 42s on pump gas, The 60s reduced 30% to account for e85 is about 42 (if i did the math right)
    have you done a dyno, or any acceleration timing?
  19. #19 Re: Planning my mods, need advice
    Jul 2017
    macomb mi
    I dynod back before I installed rockers and a upgraded fuel pump and made 255whp and that was maxing out my fuel pump tune was done a zzp by tim but yea I first did all the supporting mods and maintence like headers spark plugs etc. tuned then dropped pulleys then a year later I did e85 and just got injectors tuned dropped some more pulleys. then did a fuel pump and rockers dropped some more pulleys a few months later and that's where im at now going to be installing the intercooler in a few weeks and putting on some wide tires and lightweight wheels once my current tires are toast so my trans dosnt hate me
  20. #20 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    How much of a difference did the rockers and fuel pump make in the but dyno? Seems like with the IC you should be at 300whp
  1. New guy advice for mods
    By Cory2236 in forum Introductions/Noob Questions
    Last Post: 04-02-2017, 02:16 PM
  2. Planning next MODS.
    By rickisrad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2017, 07:29 AM
  3. what do you think? need some advice on mods.
    By gtpeddie in forum General Grand Prix Discussion
    Last Post: 06-10-2012, 12:07 PM
  4. some advice on my mods?
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 02:16 PM
  5. Mod advice from those w/o mods
    By IndeedSS in forum The Rant Forum
    Last Post: 03-09-2008, 08:26 PM
