Thread: Planning my mods, need advice
Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 241 to 260 of 272
  1. #241 Re: Planning my mods, need advice
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Just FYI, the xpz barely lopes. I can make it idle like a stock car. The XP or s1x have a decent lope.
    Can i run the XPZ Cam with the manley retainers that Intense sells?
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #242 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Quote Originally Posted by 04lss View Post
    Yes, I think so.
    I had a set of those retainers once, they fit terrible.
  3. #243 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Yes, I think so.
    unfortunately they are the only retainers i can find in stock. ZZP is sold out .
  4. #244 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Got zzp to change my order to the XPZ cam. I figure if im going to build an m90, might as well go all out. Not sure there is anything left for me to do power wise on it in addition to what i have planned.
    Gen 5 SC
    2.55 pulley
    Meth
    Whatever timing i can run without knock
    e85
    xpz cam
    ported heads
    136# springs (or the crow cams 150s)
    N* TB
    FSIC
    80# injectors
  5. #245 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Called the machine shop my dad uses for his v8 builds, and qas quoted 100 bucks to d o the valve guides and spring seats (if i go Crow springs) It would cost me more than that to buy the tools from Comp .
  6. #246 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    If you aren't going to rev it high, I'd just stick with the 136# springs.
  7. #247 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    the only thing I could see you adding is a nitrous kit, but i think you already said you weren't planning on running that. looks like a solid build. any plans for the transmission at the moment?
  8. #248 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    I reckon ill let her rev to a t least 6500. especially if i get a spare engine.
  9. #249 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by SgtMarshal View Post
    Plans yes, funds no. The money i had set aside for trans stuff is going to doing the cam the right way. When it was a VS cam, i didnt need springs, head work etc.
    Plan is to slap an input shaft, GXP chains, in a JY trans.
  10. #250 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    You'll need 150's then.
  11. #251 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Probably going to do the crow cam 150s theyre like 120 bucks cheaper than the comps, and machining to fit them is cheaper than the price difference.
  12. #252 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Alright folks,
    Help me pick my springs. On the table are:
    Crow Cams 150
    Pros: 80 bucks on closeout pricing Proper strength for an XPZ
    Cons: require machining of the spring seats.
    Manley 150 springs
    Pros: no machining, not as expensive as comp cams or PAC, probably work better with Manley retainers i ordered (only ones in stock)
    Cons twice the price of the crow springs.
  13. #253 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    I ran/run Manley 150's on both my xpz builds and haven't had any problems with them. Personally, I'm not fond of comp or crow springs because of all the breakage I've seen. PAC is probably the best.
  14. #254 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Ill probably just go that route then.
    What kind of shift points did you run? Seems like power band peak is somewhere around 6500.
  15. #255 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    The 1st one was pretty conservative...I kept shifts around 6k. My current one, I've got transmission problems, but I've taken it to 6700 and power isn't falling off at that point yet.
  16. #256 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    maybe check into the PAC 1218's. they are really popular with the gen 3/4 LS guys, so they should work for these too.
  17. #257 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Looks like theyre 130s , I think ive been told that i need 150s if i plan to run the cam out to the top of the power band at 6500.
  18. #258 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    I have decided on the manley 150s. The question is, do i need to upgrade to the 3/8ths pushrod.
  19. #259 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Hi folks, as i get ready to tear the regal down for the Cam/Meth/trans work, ive begun thinking about my fuel system. Primarily weather or not my injectors are enough.
    I have 80# Injectors, and a 340LPH pump from AEM. Now under normal circumstances i would expect this to be overkill, but im on e85.
    Do i have enough fueling to run the XPZ cam to 6500, along with METH, and a 2.5 inch pulley on the gen 5?
  20. #260 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Yes, I'm running 80's on e85 and I have plenty of headroom.
  1. New guy advice for mods
    By Cory2236 in forum Introductions/Noob Questions
    Last Post: 04-02-2017, 02:16 PM
  2. Planning next MODS.
    By rickisrad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2017, 07:29 AM
  3. what do you think? need some advice on mods.
    By gtpeddie in forum General Grand Prix Discussion
    Last Post: 06-10-2012, 12:07 PM
  4. some advice on my mods?
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 02:16 PM
  5. Mod advice from those w/o mods
    By IndeedSS in forum The Rant Forum
    Last Post: 03-09-2008, 08:26 PM
