Thread: Lets discuss 8 rib conversions
Results 1 to 8 of 8
  1. #1 Lets discuss 8 rib conversions
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Well beside it looking freaking sweet and helping eliminate belt slip. what do you guys think the advantage of doing this is? Any additional benefits?
    Oh yeah if you have an 8-rib conversion and share your opinions, you better share pics too. haha.
    This is what I am going to be using, along with the zzp mps setup. I just need to find a belt for this. Any help on finding a belt for it while I am running my 3.4, and then I'll get ones for 3.2, 3.0, and 2.8's?
    ZZ Performance
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  2. #2 Re: Lets discuss 8 rib conversions
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Just use a regular 6 rib belt for a anything down to a 3.0" pulley. There is no need to spend the extra money on an rib belt until you need it imo.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  3. #3 Re: Lets discuss 8 rib conversions
    alhambra, Il
    while I agree with your thoughts, if I am going to do it later when I run the 2.8 or below, might as well go ahead and do it now. That way it looks cool, haha.
    Steven Oliver
  4. #4 Re: Lets discuss 8 rib conversions
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Quote Originally Posted by Andrew_99GTP View Post
    if the idea of the 8 rib is to help eliminate belt slip... then why would one run a 6 rib belt on an 8 rib pulley??? that won't help belt slip. that doesnt make any sense. .... and yeah you can have belt slip with a pulley bigger than 3"
  5. #5 Re: Lets discuss 8 rib conversions
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    I run an ATI balancer, therefore I'm going to use it. 8 ribs here.
  6. #6 Re: Lets discuss 8 rib conversions
    alhambra, Il
    Are you running the zzp ati balancer? Have you got it on? does it help reduce the vibrations a little bit.
    Steven Oliver
  7. #7 Re: Lets discuss 8 rib conversions
    No other real advantage that the belt slip issue. Oh and the wow factor too.
  8. #8 Re: Lets discuss 8 rib conversions
    Las Cruces, NM
    I have the INTENSE ATI balancer. It is installed. Balance shaft is still in so vibrations are same as stock really. I got it to save my flywheel. I have read it's worth the piece of mind in the vibrations it eliminates.
  1. Lets take a head count here!
    By gmboy in forum Canada
    Last Post: 12-29-2017, 09:11 PM
  2. ABS Trouble...lets see if this forum can step it up
    By Zef_66 in forum Brakes/Suspension/Chassis
    Last Post: 01-16-2008, 08:13 AM
