Thread: Which push rods should i use with VS camshaft and LS7 lifter
Results 1 to 6 of 6
  1. #1 Which push rods should i use with VS camshaft and LS7 lifter
    Jun 2018
    Long Beach, MS
    Trying to figure out which push rods to use.
    Got ZZP VS cam shaft and LS7 lifters. The stock push rods are to long.
    6.95 or 7.00 push rods?
    The push rod tool I get 2.5 turns.
    Measuring the push rod tool is 6.93"
    Turning the bolt on rocker arm I get 1.5 turns
  2. #2 Re: Which push rods should i use with VS camshaft and LS7 lifter
    The Boss Iceman6669's Avatar
    Jun 2011
    6.95 has been the size I have seen most guys end up using on a CompCams cam and LS7 lifters.
    2011 F-150 Yote powered
  3. #3 Re: Which push rods should i use with VS camshaft and LS7 lifter
    looking over my old emails I believe I ran stock pushrods with 105# springs and new retainers and seals on the valvetrain
  4. #4 Re: Which push rods should i use with VS camshaft and LS7 lifter
    wtf is the edit button to edit my original post? anyways I ran modified retainers from zzp.
  5. #5 Re: Which push rods should i use with VS camshaft and LS7 lifter
    Jun 2018
    Long Beach, MS
    The 6.95 are the ones i was thinking about using. Just trying to make sure i use the right ones.
  6. #6 Re: Which push rods should i use with VS camshaft and LS7 lifter
    Likely the lifter has enough uh..movement that it'll work.
  1. Wtb cam lifters push rods
    By GTPMidknight in forum Wanted To Buy - Parts
    Last Post: 07-12-2014, 09:54 PM
  2. Push rods
    By l67fanatic in forum General Tech Discussion
    Last Post: 03-17-2013, 09:15 AM
  3. push rods
    By kenconerly in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2012, 07:25 AM
  4. Push rods junk?? and Y??
    By blown383z28 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2011, 10:22 PM
