Thread: Ran a 12.3 @110 (Do i go smaller pulley?)
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 Ran a 12.3 @110 (Do i go smaller pulley?)
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    Ran my best of 12.3 @ 110 last night with hoosiers and I love them! I feel the car is limited as I will get some KR with 93 and a bottle of boostane 116. When I go to the track I will add another bottle and get no KR at all. Rather do this than lower timing. With that if I reset the trims I will be an 11.8 afr like last night but after a week it will trim it self back to a 11.5 afr. Now I know the m90 is not very efficient after a 2.8. IS it really worth it to drop to a 2.7 or 2.6? Rather than find a ported gen 5 and adapter in 3 weeks before the track closes. The car is pretty stripped and weights 3375.
    https://www.youtube.com/watch?v=3yH80HMLQeo
    Ran a 12.3 @110 (Do i go smaller pulley?) Attached Images
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  2. #2 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    Jul 2008
    Hooksett,NH
    02 Regal GS
  3. #3 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    meth would let you run more timing. seems like we got the same set up other then you have a cam, i got rockers, im at 21ยบ wot with meth.
  4. #4 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    May 2008
    Schuyler, NE
    Nice times.
    What are you running for timing? You might gain more by advancing it on 93 octane versus dropping a pulley.
  5. #5 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    May 2008
    Schuyler, NE
    Also, what are you cutting for a 60ft?
  6. #6 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    time slips say 1.8 ish.
  7. #7 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    May 2008
    Schuyler, NE
    Missed that. Are you running qtp's? Your 60ft definitely has room to improve. You've got an 11 second car there with some tweaks.
  8. #8 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    Jul 2008
    Hooksett,NH
    I am at 15-16* of timing.
  9. #9 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    May 2008
    Schuyler, NE
    You should advance timing to around 19ยฐ if you can run that much without kr.
    Get that 60ft into the 1.7's. Cable the rear and let air out so you aren't spinning. You'll be really close to 11's.
  10. #10 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    Jul 2008
    Hooksett,NH
    A month ago when I ran a 12.7 @109 I was trying an 11.5 afr and 17* of timing and I got some KR but it was not my best run as the trap suffered a tad. I will try and go 17* of timing and see how it goes. I am really looking for another 12.3 or 12.2 pass in the next 3 weeks before the track closes.
    02 Regal GS
  11. #11 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    May 2008
    Schuyler, NE
    If you aren't traction limited, a smaller pulley will decrease your 60ft. That will usually help your 1/4 mile time more than a few extra hp from timing.
  12. #12 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    Jul 2008
    Hooksett,NH
    The video is above for perspective on my launches. I know a smaller pulley will need a tweak in the tune as it is making more air.
    02 Regal GS
  13. #13 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    May 2008
    Schuyler, NE
    A pulley alone won't require a retune. The maf measures air and adds or subtracts any fuel needed.
  14. #14 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    Jul 2008
    Hooksett,NH
    I went to check my gen3 and I don't have a machined snout so I am stuck with the 2.8 unless I buy the machine tool. I will try another * of timing to see what happens. I am shifting at 6200rpm. I looked at my dyno sheet and it says no more power is made after 6k but per zzp it says power is made to 6200.
    02 Regal GS
  15. #15 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    Kemmerer, Wyoming
    what valvesprings are you running?
  16. #16 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    im on a stock cam, but tried shifting at 6200, rockers and springs, the time spent spinning just rpms and no power slowed me down. backed em down to 5800 and went faster.
  17. #17 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    May 2008
    Schuyler, NE
    If you're only making power to 6k, I wouldn't shift any higher than that.
  18. #18 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    Jul 2008
    Hooksett,NH
    Quote Originally Posted by SgtMarshal View Post
    130#
    02 Regal GS
  19. #19 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    Jul 2008
    Hooksett,NH
    I am going to try and attach my dyno sheet as the thumbnail will not let me anymore or delete for some reason.
    02 Regal GS
  20. #20 Re: Ran a 12.3 @110 (Do i go smaller pulley?)
    May 2008
    Schuyler, NE
    I'd shift at 5900 with that dyno.
  1. Smaller Pulley on '00 GTP
    By usdmaf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-15-2014, 08:05 AM
  2. Do I really need a smaller belt with my smaller pulley?
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 04-04-2014, 12:36 PM
  3. Installing a smaller pulley!?!??
    By Ahaas96 in forum Introductions/Noob Questions
    Last Post: 03-07-2014, 03:23 PM
  4. smaller pulley
    By kunkelz28 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2010, 02:01 PM
  5. new belt w/ smaller pulley?
    By PonchoDvr4Lfe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 05:54 AM
