Thread: Maxing out the Lumina!
Results 1 to 3 of 3
  1. #1 Maxing out the Lumina!
    Nov 2011
    Bayamon, Puerto Rico, Puerto Rico
    Hello guys I've got a Lumina with a L67 swap.
    Mods are
    -stage 1x cam
    -yellow valvesprings
    -tog headers
    -full 3" exhaust
    -3.4 pulley
    -autolites 104 iirc
    -180 tstat
    -4" intake
    I wanna run e85 with this set up and max it out. Is this doable? What else do i need?
  2. #2 Re: Maxing out the Lumina!
    You'll need larger fuel injectors, larger fuel pump and a smaller pulley if you want to "max" out your setup with the same camshaft.
    Think 60 or 80lb/hr injectors, 255 or likely a 340lph fuel pump and whatever size pulley you want to run like a 2.8.
    Going E85 without doing anything else and keeping everything else the same doesn't seem worth it though.
  3. #3 Re: Maxing out the Lumina!
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Agreed. E85 is a hell of a drug. I've got no ic on a Gen v setup (2.7 pulley) with 26* timing wot. I don't see knock on this setup shifting at about 6200-6300.
  1. Finally maxing out my stock fuel pump
    By GTPpower in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2015, 06:58 AM
  2. What's needed to top swap a lumina?
    By ThatSexyGuy in forum General Grand Prix Discussion
    Last Post: 03-02-2015, 07:54 PM
  3. BMW M3 vs lumina
    By stonecold0469 in forum Track Sessions and Kills
    Last Post: 12-03-2011, 10:48 AM
  4. L67 Lumina 3" exhaust?
    By stonecold0469 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2011, 11:34 PM
  5. Maxing out stock injectors? but don't think i should be.....
    By blackgrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2011, 11:44 PM
