Thread: EVAP Canister Purge Switch with 3 lines?
Results 1 to 3 of 3
  1. #1 EVAP Canister Purge Switch with 3 lines?
    Jul 2015
    Kalamazoo, Michigan
    Hello, Everyone!
    I have been getting a P0171 code every once in a while on my 1997 GTP and today while I was tracing vacuum lines I noticed there was a missing vacuum line on the bottom of the EVAP Canister Purge Switch. It has an elbow, but it goes to nothing. I put a cap on it and took it for a drive and my trims were sitting right around 0. Could this be the source of my vac leak? I didn't notice any noticeable vac from the elbow when I put my hand on it with the engine running, but should I? The part number for the part I'm looking at is 24506192 and it also says FASCO on it.
  2. #2 Re: EVAP Canister Purge Switch with 3 lines?
    Jun 2018
    va
    You figure this out? Took my stuff apart to do new gaskets and saw that there was an elbow not connected to anything. Not sure if it's supposed to be
  3. #3 Re: EVAP Canister Purge Switch with 3 lines?
    It's supposed to be open to the air. Not many here have that valve. It's a one year SC only thing.
  1. Vacuum lines to/from Evap switch on 1997 GTP
    By Keith1951 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2016, 09:09 PM
  2. Canister vent & purge solenoids
    By Redneck1989 in forum General Tech Discussion
    Last Post: 07-31-2016, 12:08 PM
  3. Evap canister purge vent blocked
    By Pauld627 in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-14-2016, 05:12 PM
  4. Gen V evap purge valve with N*
    By dezebe1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2014, 07:50 PM
  5. EVAP canister purge valve vacuum line part number
    By Freimuth in forum General Tech Discussion
    Last Post: 04-18-2012, 11:00 AM
