Thread: HELP ! Fuel rail shooting gasoline out
Results 1 to 10 of 10
  1. #1 HELP ! Fuel rail shooting gasoline out
    May 2018
    Long Island, NY
    This is my first post on this forum. I was a part of clubgp years and years ago. Anyway, my 2000 Grand Prix GTP has not been started in about 6 years, it's original problem was a bad fuel pump (or so I believe).
    This weekend I replaced:
    Fuel pump
    Fuel filter
    Coolant Flush
    Battery
    Oil change
    Spark Plugs (Auto Lite)
    I used Marvel's Mystery Oil To lubricate the pistons
    & I also pulled the ICM Sensor to crank the engine before attempting to start it.
    The car has about 110K miles on it but I replaced the engine shortly before I stopped driving it (Thanks Ed Morad!) with an L32 with about 15K miles on it. When I cranked the engine, I could hear the Pistons moving and I know that's a good thing.
    TLDR START HERE;
    When I attempt to start the car, gasoline literally shoots out of the Bleeder (Schader) Valve on the fual rail... Like 4 feet high (At least I know the pump works !). Why would this be? I tried to google answers but it's a no go. Should I replace the valve (I googled the valve but can only find the A/C one; can it even be replaced? Fuel pressure regulator? I also fear that I may have accidentally damaged a fuel line when I jacked up the car to replace the fuel filter, part of one of the lines was under the jack. It looks undamaged but maybe I missed something?
    Any information or help would be GREATLY appreciated. I can't wait to start driving this car, again.
  2. #2 Re: HELP ! Fuel rail shooting gasoline out
    Kemmerer, Wyoming
    the shrader valve might be loose, the part inside I mean.
  3. #3 Re: HELP ! Fuel rail shooting gasoline out
    May 2018
    Long Island, NY
    Thanks for the reply... The rubber part, right? I was thinking that but when I google replacement Schader valves, I get no accurate results, only the A/C replacement valve, nothing for the fuel rails. I was thinking that maybe it deteriorated over time.
  4. #4 Re: HELP ! Fuel rail shooting gasoline out
    push the pin inside in and out a few times, then turn the key to run, see if that makes it tight again. mine got stuck down once too. fiddled with it, all good.
  5. #5 Re: HELP ! Fuel rail shooting gasoline out
    May 2018
    Long Island, NY
    When I put the key in accessory mode and the pump primes, a little bit of gas leaks out and when I push in the pin, extra air and more gas comes out. So wouldn't that mean that it's not stuck because of the difference in the expulsion of air/gas when pressed?
    Shoots..like4-5 feet high. It's crazy
  6. #6 Re: HELP ! Fuel rail shooting gasoline out
    lol you got good pressure then. seems like it was fine when parked, so id think its just stuck down a bit. give it a fiddling see if it stops leaking. dont be scared to move the pin side to side either, theres a seat valve in there, could be crusty from sitting.
  7. #7 Re: HELP ! Fuel rail shooting gasoline out
    it's the same basic thing as a tire valve. A little working it like Scott says is likely to fix it.
  8. #8 Re: HELP ! Fuel rail shooting gasoline out
    May 2018
    Long Island, NY
    I suppose it was stuck. I pressed it down once (as I had many times the day before) and now it's fine. Go figure
  9. #9 Re: HELP ! Fuel rail shooting gasoline out
    Quote Originally Posted by GTPROTOTYPE View Post
    now dont touch it again, dont even look at it hard. after i posted i recalled what rail i had on that was doing the same. it was used one that had been off a car for who knows how long, years is my guess. i cut it up to make a custom fuel rail.
  10. #10 Re: HELP ! Fuel rail shooting gasoline out
    SE Level Member thekidinbuff's Avatar
    May 2013
    Buffalo, NY
    I know this isnt helpful but this post made my day. Thank you. I'm glad you got it fixed.
    2002 Pontiac Grand Prix GTP
    2006 Pontiac GTO LS2 M6
  1. Replies: 7
    Last Post: 07-15-2015, 03:41 PM
  2. The retainer/clip the secures the fuel line to the fuel rail.
    By Sudden in forum Wanted To Buy - Parts
    Last Post: 06-22-2013, 05:20 PM
  3. Dual Fuel Hypothetical E85/Gasoline
    By bsharpminor in forum General Tech Discussion
    Last Post: 02-26-2013, 03:12 PM
