Thread: AC delete pulley
Results 1 to 5 of 5
  1. #1 AC delete pulley
    Mar 2018
    Tucson,AZ
    So I was wondering what everyone was doing with AC if it's being removed...I want to eliminate the compressor as dead weight now since all mine is yanked and want to either just remove and run a smaller belt or use a dummy AC pulley...
    What is everyone's suggestion on the topic?
  2. #2 Re: AC delete pulley
    Theres a pulley that you can buy from nearly any auto parts store.
    I do have trouble believing you are in Tucson and wanting to delete ac though. You must like that "dry" heat.
  3. #3 Re: AC delete pulley
    dorman ac delete bracket and pulley. 45 bucks ish. you use the same belt.
  4. #4 Re: AC delete pulley
    Kemmerer, Wyoming
    the geometry is wrong to just run a shorter belt, it will end up hitting on something, so you have to use the ac delete pulley.
  5. #5 Re: AC delete pulley
    Mar 2018
    Tucson,AZ
    Ok AC delete pulley it is...it's not a daily so freeing up as much as I can...AC didbt work when bought the car so pulled all the lines, heater core, controls, and all that fun stuff only thing still there is the compressor and wanted to save the weight there...
  1. U Bend Delete & Resonator Delete
    By 9ordohz in forum General Tech Discussion
    Last Post: 10-23-2010, 10:57 AM
  2. AC Delete bracket and pulley from auto parts store???
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2009, 06:09 PM
  3. possible to run a smaller belt w/o ac (delete pulley)?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-24-2009, 05:07 PM
  4. Ac delete pulley
    By minichopper6hp in forum Shops and Community Heroes
    Last Post: 04-04-2009, 09:18 PM
