Thread: Have the answer
Results 1 to 6 of 6
  1. #1 Have the answer
    SE Level Member fever42's Avatar
    May 2008
    Mobile, Al
    I guess i am too old, I know i knew at one time , I have a lim which has a screw in plug ( about the size of a quarter)and two dimes welded in it
    What was this done for
    Thanks
    have the answer Thanks
  2. #2 Re: LIM
    Kemmerer, Wyoming
    it was done to reroute the coolant flow. I was suspect if you take the end cap off the same side you will see that the passage has been opened up to create a bypass. it's supposed to help with cooling on the rear cylinders or something like that, and also make it so you don't have to change the supercharger gasket each time the supercharger is removed.
  3. #3 Re: LIM
    Here's one of the whys and how to
    97-03 NA L36 UIM Failure
    The basic reasons are to eliminate coolant leak when spacing or replacing a TB, getting around having coolant in the L36 which cracks after enough heat cycles or wanting to be able to yank the upper/SC/IC without draining coolant.
  4. #4 Re: LIM
    May 2008
    Mobile, Al
    Not L36 but thanks
  5. #5 Re: Have the answer
    Kemmerer, Wyoming
    it's still exactly the same idea regardless of L67 L36
  6. #6 Re: LIM
    Quote Originally Posted by fever42 View Post
    Not L36 but thanks
    I get what you are saying, which is why I mentioned the SC and intercooler in that same blurb. Covers both the slow and the GOOOOOOO
