Thread: Started her up and after short drive, right running!
Results 1 to 3 of 3
  1. #1 Started her up and after short drive, right running!
    Nov 2011
    NY
    Ok, so in the big freeze here in NY, my 2 year old duralast gold died. Nursed it back, but first cold day again and it bit the big one! Forward another week or so and I finally got it replaced @ autozone. Started right up with new battery after slight hesitation. Took it for a little drive and filled the tank. After filling tank she started to run rough then drop to limp mode! Ran like it was on 3 cylinders. Checked obdII and pending P0102 code showed up.
    MAF? MAP?
    What's your thoughts?
    TIA
  2. #2 Re: Started her up and after short drive, right running!
    i bet the maf fuse blew, #21 iirc, marked IGN.
  3. #3 Re: Started her up and after short drive, right running!
    Nov 2011
    NY
    I didn't even think about a fuse, or fuses... Thanks Scotty, will give it a look when I get back later.
  1. Started Running e(30) today..Experiment?
    By LNVFX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2017, 10:19 PM
  2. Going up hill I lose power stalls stammers can't keep it running - just started - WT?
    By GT2001Aurora in forum General Grand Prix Discussion
    Last Post: 03-09-2015, 05:01 PM
  3. GXP clunk from park to drive, drive to reverse..
    By sasquatch094 in forum General Tech Discussion
    Last Post: 02-13-2014, 04:27 PM
  4. Can you drive without cross bars (fender support bars) for a short tiem?
    By Hippo Machine in forum Visual/Body Modifications
    Last Post: 06-29-2011, 10:47 PM
  5. ok to drive without diagonal braces for a short time?
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 09-29-2008, 09:17 AM
