Thread: any gains in porting the boost bypass passage?
Results 1 to 18 of 18
  1. #1 any gains in porting the boost bypass passage?
    like i stated, is there any gains or anything advantageous at out if porting either or both in/outlet of the boosy bypass passageway? i can imagine it'll run lean at idle and cruise or basically during vacuum. kinda like home-porting a stock throttlebody w/o fiddling around the areas of the tb blade.
  2. #2 Re: any gains in porting the boost bypass passage?
    lapeer michigan
    i dont see it doin anything becuase it works like a wastegate basically, i think?someone correct me if im wrong!!
  3. #3 Re: any gains in porting the boost bypass passage?
    If your ported it larger than the plate in it im sure you would loose boost. I dont think their are any gains to be had by porting it unless you were turbo.
  4. #4 Re: any gains in porting the boost bypass passage?
    Quote Originally Posted by my97gtp View Post
    lets assume the outlet(bottom portion) is ported and not the top/inlet, boost would be generated the same since the BBV plate is shut anyways. i think this would only be changed, if any, at cruise and idle when no boost is initiated.
  5. #5 Re: any gains in porting the boost bypass passage?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    why would you want to bypass more boost?
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  6. #6 Re: any gains in porting the boost bypass passage?
    just an observation and a 'what if' question ^_^;
  7. #7 Re: any gains in porting the boost bypass passage?
    St Louis MO
    Hmmm... it would definitely make you slower, since at the time when a percentage of air could be going through the s/c it would bypassing it. fwiw when my BBV was broken it was closed all of the time. It made boost a lot faster and I noticed no additiona; KR as some people have claimed.
    It is good to wonder about the affects of change. I compliment you for your curiosity.
    2010 Camaro SS LS3
  8. #8 Re: any gains in porting the boost bypass passage?
    Bastard Reptile's Avatar
    Kansas City, MO
    Keep in mind that the air is still going through the rotors as well, even when the bypass valve is open. IF you eliminate the butterfly alltogether, you're only gonna make about 6 psi max.
  9. #9 Re: any gains in porting the boost bypass passage?
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Quote Originally Posted by Reptile View Post
    Why would you only make 6psi max?
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  10. #10 Re: any gains in porting the boost bypass passage?
    Kansas City, MO
    Because the air recirculates up through the Bypass valve and back into the rotors. The flap is there to keep air from bleeding off and keep that from happening.
  11. #11 Re: any gains in porting the boost bypass passage?
    St Louis MO
    recycled boost?
    2010 Camaro SS LS3
  12. #12 Re: any gains in porting the boost bypass passage?
    Oklahoma
    Quote Originally Posted by IndeedSS View Post
    Exactly! Everything you come up with may not be the best idea, it may not be the worst, but its an idea. Even if you came up with the worst idea ever, discussing it and looking at it from different perspectives may bring forth other better ideas.
    That said, I cant personally see how there would be any gains in porting the Boost Bypass, but hey, here's to discussing intelligently and see what we come up with.
  13. #13 Re: any gains in porting the boost bypass passage?
    well I was discussing this with another member and he mentioned that the bottom section of the boost bypass if ported 'may' be benefitial for guys with Ics. I dunno but its another possibilty lol
  14. #14 Re: any gains in porting the boost bypass passage?
    St Louis MO
    Porting a gen 3 blower and LIM can be beneficial for those with an IC, but bypassing what gives you the power seems like it may have the opposite effect of what you are looking for. That said try out the BBV mod, and see what effects it has. If your car is like mine and it doesn't give you knock, then you will quickly find out the result of blocking off the BBV. Then you can figure the opposite may be true in opening it up further...
    disclaimer: most of the time I don't know what I'm talking about...so experiment at your own risk.
    2010 Camaro SS LS3
  15. #15 Re: any gains in porting the boost bypass passage?
    Oklahoma
    I dont know enough to really contribute, but I can work with 'may'. Its a chance, and it may come down to someone having to port one and see, but who knows what kind of knowledge we could gain on the journey there.
    Thats why Im watching this thread. You got my attention and interest. So while I may not be able to contribute anything really useful, I'll watch and see if I can learn something. Keep up the good work, hopefully other will come in here and get the discussion moving along good.
  16. #16 Re: any gains in porting the boost bypass passage?
    St Louis MO
    This has been done...I'm looking for the forum I followed the thread on.
    2010 Camaro SS LS3
  17. #17 Re: any gains in porting the boost bypass passage?
    Oklahoma
    Okay, let me ask something here, well maybe several somethings.
    1. The BBV obviously Bypasses boost. Isnt that valve also open when you are not in boost? In other words, is it in the normal intake track channeling air to the motor and when you go into boost it closes off? If that is so, wouldnt opening that up allow more air flow for when the engine isnt in boost? Just thinking and questioning out loud here folks. I dont know what if any benefit it would be, just thinking.
    2. If the BBV opening was ported, that would release boost faster, correct? How would this affect boost decel in the PCM and the possibility of flash KR? Though if you have let off the gas, I dont think this would matter much, but just something that crossed my mind.
    3. How would this affect fueling. With the BBV not being either opened or close, rather it can be just about any where in between, how would this affect fueling?
  18. #18 Re: any gains in porting the boost bypass passage?
    St Louis MO
    1. I've only seen the BBV opened or closed, except the time before mine completely stuck open. Then it was bouncing up and down at idle. I assume it is either open or closed and doesn't operate at a partial position like your throttle blade does. What I do know is when the BBV is open (low load) the air goes through the BBV and the rotors. Under heavy load it is rotors only.
    2. I don't see how it would release boost faster. I know what you are saying, but am not seeing it, I guess.
    3. I never notice a change in KR or MPG. Assumption would be that more air would require more fuel.
    I would love to here someones take, that builds performance engines, because I'm giving best guesses.
    2010 Camaro SS LS3
  1. Most Accurate Boost Guage?
    By RNUOVR in forum Off Topic Discussion
    Last Post: 01-07-2008, 03:38 PM
