Thread: Oil leak
Results 1 to 6 of 6
  1. #1 Oil leak
    Jan 2018
    Morgantown
    is valve cover gasket leaking a common issue?
  2. #2 Re: Oil leak
    Jan 2018
    Morgantown
    because mine leaks alot
  3. #3 Re: Oil leak
    The Boss Iceman6669's Avatar
    Jun 2011
    Yes. Valve covers are known to leak. There is even a recall on them. It’s most commonly the grommets that leak.
    2011 F-150 Yote powered
  4. #4 Re: Oil leak
    the grommets dont leak, but they do dry up and put less down force on the valve cover, the cover bolts have a shoulder at the end of the threads so only snug them down or they snap real easy.
    gaskets leak all the time on these, the recall only covers the front cover, or what would be your rear now due to a fiero swap .
  5. #5 Re: Oil leak
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Grab the set on rockauto and do em both. It's pretty easy and it's good peace of mind! imho
  6. #6 Re: Oil leak
    Jan 2018
    Morgantown
    Thanks everyone for the help!!
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
