Thread: Oil light
Results 1 to 20 of 20
  1. #1 Oil light
    Ohio
    Ok i need some ideas on this one. Every time i sit at a light or a stop sign or just at idle in the driveway my oil light flickers an the hud says check gauges. The second i touch the throttle the light goes back out. The oil level is fine an it doesnt seem to be loosing oil pressure. The only thing wrong that i can find is the dipstick is broken. The plastic part w/ the o-ring is snapped off the top so i pull it up to the cap an put it in like normal an it stays an seems to seal. Could this be causing my problem?
    00 GTP demodded and forsale
  2. #2 Re: Oil light
    Becca Boo MizzBecca's Avatar
    Michigan
    My oil light flickers when i turn left at all lol. Hmmmm
    I drive a POS
  3. #3 Re: Oil light
    Might be...but if you don't have a gauge...how do you know that your oil pressure is fine?
  4. #4 Re: Oil light
    Ohio
    Becca thats pretty odd may wanna look into it. ^ Yea thats true bluegtp. ill have to get my dads an hook it up an see if it shows anything. Any other ideas?
  5. #5 Re: Oil light
    Banned - Busted For Scamming
    Feb 2009
    yea, the sender is a piece of crap
  6. #6 Re: Oil light
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    aftermarket Oil pressure gauge is real easy to hook up the sender screws right in to where the idot light sensor is now and you get a actual reading
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  7. #7 Re: Oil light
    Ohio
    Well guys now its knocking so i have bigger issues than a sender its likely a rodbearing. Looks like shes gonna sit for a bit then shes gonna be gettin a tear down. Can i pull the motor out the top or do i have to drop it out the bottom?
  8. #8 Re: Oil light
    Feb 2008
    That sounds like what mine did when I spun a cam bearing. I lost oil pressure after an oil change and about a week later, it started ticking, then knocking.
    You can pull it out through the top. Remove your hood, unhook everything, and pull it. Have tons of fun getting the rear transmission bolt out. It screws in from the passenger side. The easiest way to access it is to get about 3 ft. of extensions and go though the passenger wheel well to get to it.
  9. #9 Re: Oil light
    Ohio
    ^ thanks for the tips im def gonna need um. Ive pulled the motor outta my buddies mr2 a million times but never pulled the motor outta my gtp yet. but this week starts that whole new ball game. good thing i enjoy workin on my car!
  10. #10 Re: Oil light
    Feb 2009
    you dont have to remove the hood, so dont. just unhook the hood shocks and prop it straight up
  11. #11 Re: Oil light
    Ohio
    good tip mini.
  12. #12 Re: Oil light
    Ohio
    ok when buying my new rod bearings. im gonna prob get them from intense or zzp. is a quantity of 1 all 6 sets or is it a single set for 1 rod. neither sight specifies
  13. #13 Re: Oil light
    Feb 2009
    thats gonna be a set for $25 it looks like. if you spun a rod bearing your crank is gonna need ground. you might just wanna look for a new shortblock
  14. #14 Re: Oil light
    Ohio
    yea but im tryin to fix this on a tight budget. i know somethings gonna have to happen w the crank as its prob not in good shape but idk that i can find or afford a short block thats complete an not got a million miles on it
  15. #15 Re: Oil light
    Feb 2009
    well you will be wasting your time and money if the crank is bad and you dont do anything about it. putting new bearings on a scored crank is sure quick death for the new bearings.
  16. #16 Re: Oil light
    Ohio
    well im not gonna just put new bearings on a screwed crank ill def have it ground or buy another crank but shortblock is probably out of my budget. could i just get it ground to .010 under an buy those bearings instead of the standards?
  17. #17 Re: Oil light
    Feb 2009
    the machine shop will determine if .010 will get it or not, depends on the damage. i didnt say you needed a shortblock, i said it might be cheaper if there was any other damage. do yourself a favor and replace the cam bearings also, they are like $25 for the set, and if they go bad, so does your oil pressure.
  18. #18 Re: Oil light
    Ohio
    yea well see what i truely find once i get into it. ill do the cam bearings aswell. might as well ill be right there. i so wish i had a little extra cash so i could get an s1x an put it in aswell while i have the motor out but o well maybe in awhile i can get one. right now the goal is not modding its fixing so that i can drive again.
  19. #19 Re: Oil light
    May 2008
    McHenry IL
    first step is to rip her apart =]
  20. #20 Re: Oil light
    Ohio
    ^ yea exactly
  1. ABS Light On
    By Techyetti in forum Brakes/Suspension/Chassis
    Last Post: 11-10-2009, 01:15 AM
  2. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  3. ZZP dp & SES light
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 01:47 PM
  4. help... my ses light is on
    By kingd44 in forum General Tech Discussion
    Last Post: 03-07-2008, 09:45 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
