Thread: Boost gauge problem
Results 1 to 9 of 9
  1. #1 Boost gauge problem
    Dec 2017
    La
    recently bought a 2001 regal gs. I figured since the cars are so similar I might could get some help here.
    Today I fixed the cluster issue where the digital odometer and boost gauge wasn't working. I wired in the resistors and now everything works but my boost gauge is showing 0.0. I've checked that the boost control actuator isn't stuck, and there are no vacuum leaks. Any ideas?
  2. #2 Re: Boost gauge problem
    map sensor is what its reading for boost. might be bad, or its got a vac leak.
    it makes no boost till you get into the gas. round town next to nothing.
  3. #3 Re: Boost gauge problem
    Dec 2017
    La
    Wouldn't it trip a code if it was a bad map sensor? I've checked vacuum lines. Found and fixed all leaks.
    So far I've only driven this car down my driveway and back but I would think it would have moved from 0.0. I've also rev'd it up in park with no change.
  4. #4 Re: Boost gauge problem
    wont make boost in park, need to have a load on the engine. chances are things are just fine. gonna have to get on it to see the gauge move.
  5. #5 Re: Boost gauge problem
    Dec 2017
    La
    Ah ok, I'll reasses when I can actually drive it.
  6. #6 Re: Boost gauge problem
    Nov 2017
    maitrang7995
    Lưu lại tối về tìm hiểu mới được
    Book vietnam cycling tours, vietnam tours, vietnam package tours at Easy Indochina Travel
  7. #7 Re: Boost gauge problem
    May 2017
    Dirtyzville, Mizzery
    Mine made boost at idle just fine.
    Usually it's turbo cars that won't make jack for boost at idle or revving without load.
    Fast forward to about 1:10~.
    https://www.youtube.com/watch?v=yMCUElymQq8
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  8. #8 Re: Boost gauge problem
    Dec 2017
    La
    Quote Originally Posted by blueguy91 View Post
    Does your car have a factory gauge?
  9. #9 Re: Boost gauge problem
    May 2017
    Newp. Not a Regal.
    Nor would I ever try to use a factory WBody gauge for anything. They're all garbage.
    Have you actually scanned via something live feed it to make sure there aren't any leaks? If it's reading fuel trims @ 16.4 then you've still got a leak which could be causing the issue. However it might not just be vacuum lines. Could be a bad MAP like Scotty said; or LIM gaskets that need replaced along with the EGR accordion gold tubing could also be an issue. Lots of possibilities.
  1. Boost gauge showing maximum boost when not touching gas pedal
    By NotEnoughGPs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-09-2017, 10:59 PM
  2. Boost gauge / add a fuse problem
    By Hockey89 in forum How To Write-Ups/Tech Tips
    Last Post: 04-04-2013, 09:02 PM
  3. Boost Gauge Problem
    By Konvinced89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2013, 01:38 PM
  4. boost gauge problem
    By jersey jok3r in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2011, 03:33 AM
