Thread: Nic Cam Compression Ratio
Results 1 to 9 of 9
  1. #1 Nic Cam Compression Ratio
    Feb 2018
    Canada
    Hey currently rebuilding my l67 for my 2000 GTP Im trying to decide compression ratio with a NIC Cam? 8.5:1 or 9.9:1 I will be using JE Forged pistons the block has been lined honed got ARP main studs and King xp Main and Rod bearings along with l32 Rods. Im running a double roller chain and 136 valve springs I also have a Gen V feeding a stage 2 Intercooler and Pacesetter headers. My question is what kind of pulley can I run with the higher compression or should I stick with the lower compression and up the boost?
  2. #2 Re: Nic Cam Compression Ratio
    The Boss Iceman6669's Avatar
    Jun 2011
    If you are gonna be on the blower, Id recommend the higher compression ratio.
    2011 F-150 Yote powered
  3. #3 Re: Nic Cam Compression Ratio
    May 2008
    Schuyler, NE
    That^^
    Pulley size is going to depend on what fuel you're running and how well your intercooler works.
  4. #4 Re: Nic Cam Compression Ratio
    Feb 2018
    Canada
    In only have 94 available in my area But I also have Meth Injection... Just trying to get some idea of what pulley can be run with this cam and higher compression.
  5. #5 Re: Nic Cam Compression Ratio
    im on a 2.8 with meth, high comp l36 block stock cam but i have 1.95 rockers. and a fsic. i make about 12-13 psi.
    you might be able to run a 3.0, 3.2, this is where having a few pulleys on hand helps out a lot, you never really know what its gonna like best. need to play with it.
    do not use l36 valve springs, you want like 130 lb springs with a xp cam.
  6. #6 Re: Nic Cam Compression Ratio
    Kemmerer, Wyoming
    he's going to run an NIC cam with forged pistons
  7. #7 Re: Nic Cam Compression Ratio
    still dont want to run stock springs on any aftermarket cam.
  8. #8 Re: Nic Cam Compression Ratio
    May 2008
    Schuyler, NE
    I think he is saying 136# valve springs, not L36 valve springs.
  9. #9 Re: Nic Cam Compression Ratio
    lets hope so, i read it as using L36 valve springs. re reading it looks like 136 lol the skim factor got me again.
  1. Boosting High Compression vs Low Compression M90 Setup
    By Impala131 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2014, 07:08 PM
  2. No compression
    By carbon in forum General Tech Discussion
    Last Post: 12-22-2011, 09:12 PM
  3. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  4. Bad Compression?
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2009, 01:22 AM
  5. what is my differential ratio, and first gear ratio?
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-07-2008, 09:31 AM
