Thread: Low coolant light off and on
Results 1 to 13 of 13
  1. #1 Low coolant light off and on
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    My 2002 GTP has been having the low coolant light come on and turn back off multiple times while driving, in addition the temperature will range from normal to 3/4 of the way up the gauge after it's warmed up. 2 years ago I did the LIM job with aluminum elbows and all has been well since then, this is a new development. I've added coolant to the reservoir as well as topped of the rad when the car was cool. Any other ideas?
  2. #2 Re: Low coolant light off and on
    so it keeps taking coolant when the light comes on and off? so its actually low?
  3. #3 Re: Low coolant light off and on
    Feb 2009
    Roanoke, VA
    The coolant light is going off and on while driving. After I let the car cool down the other day I added some coolant into the reservoir and uncorked the radiator and added maybe 8oz of coolant directly to the radiator. Didn't make any difference, driving right after, I was still getting the coolant light coming on and going off with temperatures fluctuating as well.
  4. #4 Re: Low coolant light off and on
    take it out and clean it or replace it, level sensor in the rad. take the pass side head light out and you can see it in the side of the rad tank.
    or just unplug it and never see the light again.
  5. #5 Re: Low coolant light off and on
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    haha I agree! lol mine did this while clogged with dex. Just removed, cleaned, and good as new!
  6. #6 Re: Low coolant light off and on
    Feb 2009
    Roanoke, VA
    Do I not need to be concerned about the uptick in temperatures and how much they are fluctuating?
  7. #7 Re: Low coolant light off and on
    that was the part of is it low every time you check it?
    if you sit and idle temps go up, drive they drop. if its hot driving on the hwy or goes up and down driving you might have trapped air.
  8. #8 Re: Low coolant light off and on
    Aug 2017
    Raytown, MO
    Sorry Brammer, I didn't see the part about your temperatures. Scotty is right. Usually this is caused by trapped air. I chased this for months and used the correct bleed procedures and everything from the factory service manual with no avail! Finally had a tech do one of those fancy "negative pressure" fills and haven't had issues since. (although I should say this is a bit different because this is after rebuilding my engine from scratch and it was dryer than a bone when I started, so might not apply here).
    P.S. ONLY use the bleed screw with the engine OFF!
    If it still has issues, and it's not leaking at all after being bled properly, I'd suspect water pump failure or a clog somewhere.
  9. #9 Re: Low coolant light off and on
    i idle it till hot. and the fans come on, this way you know the t stat is open. then bleed it.
  10. #10 Re: Low coolant light off and on
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by wstefan20 View Post
    You may have been chasing your tail with the trapped air due to your own advice...engine should be running when using the bleed screw on the t stat housing!
  11. #11 Re: Low coolant light off and on
    Aug 2017
    Raytown, MO
    Quote Originally Posted by 231FUN View Post
    Not according to the GM dealer tech that I talked to, or the factory service manual I have right in front of me...
    Makes sense why not with the engine running. The bubbles are going to be pumped straight past the orifice and back into the system
  12. #12 Re: Low coolant light off and on
    Dec 2011
    Ontario,Canada
    Regardless of what the tech or the GM manual says W body/3800 folks have been doing it this way for years...it's what works! Bubbles are going to travel to the highest point which is straight out the bleeder on the t stat housing when the t stat is OPEN with engine RUNNING at temp...that's what makes sense
  13. #13 Re: Low coolant light off and on
    GT Level Member Gregorius's Avatar
    Davenport, IA
    Ehh.... Engine hot so T-Stat is open.
    Engine off.
    The water pump will foam the air into the coolant, and it *air* won't come out of the bleeder, just a little foam....
    1) But Yeah: First is it actually low on Coolant?
    Listen for the waterfall sound under the dash when starting cold. Trapped air in the heater core being displaced means Low Coolant.
    A radiator that takes more than a quart of coolant, means Low Coolant.
    Coolant disappearing from a refilled overflow tank means it <the cooling system> is leaking, or not yet full, which means, Low coolant
    2) If it's not low, or consistently taking more coolant, is there air trapped in the system? Bleed it. Engine warm, engine off.
    I open the bleeder, and squeeze and hold the rad hose to force air out. Then tighten the bleeder with one hand then release the hose. Milks coolant into the system. Restart the engine for a few secs, Engine off. Let in sit for a minute, then repeat, open bleeder, squeeze hose....do that 3 times or until you squeeze the hose and clean coolant squirts out. That's usually enough to get the major air pockets out.
    3) So it's not low on coolant, and you think most of the air is gone...but the engine is hot, the gauge still says it's too hot.. but cold radiator, and/or cold hoses?.... means *No Flow* Bad water pump, stuck t-stat or a blocked radiator.
    That's what I would check first. If it's not Dexcool gunked or the blades aren't corroded off the water pump... oil in coolant, or the oil looks like a milkshake... Then I would start worrying.
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  1. Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    By JessicaRebel in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 08:37 AM
  2. Low Coolant Light
    By rvnwlf in forum General Tech Discussion
    Last Post: 07-14-2013, 06:00 PM
  3. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  4. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
