Thread: 2000 GTP Misfire
Results 1 to 15 of 15
  1. #1 2000 GTP Misfire
    Jul 2014
    Indiana
    Okay so I just got a new GTP the mods are 3.4 pulley, pacesetter headers, 3" inch zzp exhaust, wizaird intake system, zzp tuned. I have a aeroforce scanner and i'm getting a misfire on cylinder #4 at idle. Now it goes away if you turn on A/C or accelerate. My scan gauge does not read any misfires under accelerating. I'm wondering if anyone would know why i'm getting these misfire?
  2. #2 Re: 2000 GTP Misfire
    Swap plugs around, see if it follows.
  3. #3 Re: 2000 GTP Misfire
    May 2017
    Dirtyzville, Mizzery
    Same with injectors.
    Check vacuum lines and coil packs, too.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  4. #4 Re: 2000 GTP Misfire
    GTP Level Member buickman104's Avatar
    NYC
    Are you getting any codes or pending check engine lights?
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #5 Re: 2000 GTP Misfire
    Jul 2014
    Indiana
    No I'm not getting any check engine lights. Coils are new along with plugs. They are autolite 104s. I got injectors from zzp just stock but they were tested good before I got them
  6. #6 Re: 2000 GTP Misfire
    Jul 2014
    Indiana
    Also forgot to mention new 10.5mm plug wires from zzp. New idler pulley, water pump, crank sensor, new lim gaskets.
  7. #7 Re: 2000 GTP Misfire
    Sep 2017
    Arizona
    what vacum lines should be checked
    Quote Originally Posted by blueguy91 View Post
  8. #8 Re: 2000 GTP Misfire
    did this miss come after the plug change? if so you likely cracked the spark plug. swap it with the one next to it, see if the miss moves.
    you might just see a black line in the plug too, then you know its cracked.
    or you got a chipped piston.
  9. #9 Re: 2000 GTP Misfire
    Nov 2011
    NY
    Air/Fuel/Spark...
    with misfire, swap plug (check gap too), wire, coil pack, then injector. Do this to see if the misfire follows, if so, you've found your problem. If not, then compression test, problem could be heads (valve) or worse, as Scotty says, a piston with a hole in it.
    I'm going to bet coil pack
  10. #10 Re: 2000 GTP Misfire
    Jul 2014
    Indiana
    What should a compression test run with a motor that has 212 on it?
  11. #11 Re: 2000 GTP Misfire
    how about some back story, why i asked the questions i asked.
  12. #12 Re: 2000 GTP Misfire
    It might vary some but 150-165ish give you take some.
    So long as one cylinder is way low compared to the others, like if all are at 160 but cylinder 2 was at like 130 then you may have an issue.
  13. #13 Re: 2000 GTP Misfire
    Jul 2014
    Indiana
    Sorry scotty.. the car was my dad's he had it for 10 years. He meticulously took care of his vehicle(s). Each cylinder was reading 150 - 160.. also even after plug changes it's been doing it for the last year or so he hasn't figured it out.. it's a weird misfire..
  14. #14 Re: 2000 GTP Misfire
    NYC
    I had constant misfires on cylinder 4 for about a year until I started getting other cylinder misfires and it turned out to be a crank sensor.
  15. #15 Re: 2000 GTP Misfire
    Sep 2017
    Arizona
    Quote Originally Posted by buickman104 View Post
    Could the problem also be the fuel pressure regulator??
    Sent from my LGMS550 using Tapatalk
  1. 2000 pontiac grand prix gt sedan bronzemist color 2000 obo
    By wavedout33 in forum For Sale - Vehicles
    Last Post: 02-09-2013, 07:25 AM
  2. Cyl 5 misfire. Tried everything
    By Kasey in forum General Tech Discussion
    Last Post: 10-10-2011, 06:16 AM
  3. 2000 GTP info center in a 2000 GT?
    By ZachBW55 in forum Visual/Body Modifications
    Last Post: 06-24-2011, 01:24 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
