Thread: Intercooler pump wiring question
Results 1 to 10 of 10
  1. #1 Intercooler pump wiring question
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey for those of you that have an intercooler I was wondering what size your power wire is. I'm just curious my pump seems to flow ok but I bought the kit used and the guy included the relay harness but the fused power wire is really small either 18 or 20 gauge. I was wondering if that was big enough or if I should run a 12 gauge or something instead?
    Sent from my LG-H918 using Tapatalk
  2. #2 Re: Intercooler pump wiring question
    Oct 2011
    Toledo, OH
    Not sure what wire you are talking about, but 20ga wire isn't going to drive an intercooler pump. Our windshield wiper fluid pump has bigger wire.
    But if you are talking about the wire that triggers the relay, that can be pretty small because it's basically only a signal wire, like an amp remote wire.
    2005 GTP - Graystone Metallic|SPO grills&spoiler/SE lip/Carbon Fiber INFERNO hood
    7"
    Spectre|3.4 MPS|42lb Blue Giants+E85+Walbro 450lph pump
    SpeedDaddys|AL605|Vogtlands on FE3s|Vinnie's Spacers on solid lowers|Intense poly uppers|
    Dorman + Addco sway bars|Drilled/slotted rotors|Plasti-dip 17" QP2 at +27 offset
  3. #3 Re: Intercooler pump wiring question
    Oct 2015
    Quote Originally Posted by industrialfish View Post
    Ya I'm talking about the actual power wire. I thought it looked just way to small.
  4. #4 Re: Intercooler pump wiring question
    Oct 2011
    Toledo, OH
    Quote Originally Posted by suitercrew View Post
    Well good news. If it's a Bosch pump, it only draws 2.5A continuous. Low pressure, high flow. 20ga isn't rated but would work if it's not a long run. 18ga would be fine.
  5. #5 Re: Intercooler pump wiring question
    Nov 2011
    NY
    Look on the wire, all wire is labeled. You want 14awg as a minimum. Remember the fuse protects the wire, if wire is that small, any issue and the wire will burn up and open the circuit, then no pump! If you're going to use the smaller wire, then make sure the fuse is smaller as well.
  6. #6 Re: Intercooler pump wiring question
    Oct 2015
    It is a bosch pump. I would have really thought it drew more power then that though.
  7. #7 Re: Intercooler pump wiring question
    Kemmerer, Wyoming
    the guy that makes the phenolic intercoolers uses a voltage booster to increase coolant flow while in boost. I don't know at what point diminishing returns becomes a factor or how much is too much, but obviously more voltage is a good thing for the intercooler pump.
  8. #8 Re: Intercooler pump wiring question
    Oct 2015
    Well I just did some research and sure enough it seems the bosch pump tested at only drawing 3amps of current. So I already bought a new fused 12 gauge wire so I will put it in anyway but it looks like its probably unnecessary.
  9. #9 Re: Intercooler pump wiring question
    Oct 2011
    Toledo, OH
    It's believe it's that low because it's not producing a lot of pressure, it's not working "hard" . I would have still suggested upgrading the wire anyway. Just make sure you use only like a 5amp fuse so the fuse blows before the pump catches fire in case of a problem.
  10. #10 Re: Intercooler pump wiring question
    Kemmerer, Wyoming
    I would be really surprised if the intercooler systems actually were low pressure. If these systems really were "low" pressure, we could used 50 dollar "Rule" pumps that flow huge amounts of fluid, but they are medium or high pressure, so the pump needs more voltage.
  1. Intercooler relay and pump wiring?
    By Pure2sin in forum General Tech Discussion
    Last Post: 03-29-2015, 02:39 PM
  2. Intercooler pump relay wiring
    By samuelcb409 in forum General Tech Discussion
    Last Post: 07-05-2013, 05:53 PM
  3. Intercooler pump wiring
    By triebenbach07 in forum General Tech Discussion
    Last Post: 05-09-2012, 09:16 AM
  4. Intercooler pump wiring
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2012, 05:39 AM
  5. Intercooler Pump Wiring
    By QwikGT in forum General Tech Discussion
    Last Post: 10-31-2008, 08:38 PM
