Thread: How do you run pcv through oil cap and intake?
Results 1 to 3 of 3
  1. #1 How do you run pcv through oil cap and intake?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys I know there's a post somewhere here but i can't find it. I forgot the details of the process but I believe you can drill your stock oil cap and hook a vacuum line up to it and plumb it to the throttle body for pcv function. Where I'm confused is I don't remember where the vacuum line has to connect on the throttle body. I think it was after the MAF but before the throttle plate. Can anyone confirm this? Thank you.
    Sent from my LG-H918 using Tapatalk
  2. #2 Re: How do you run pcv through oil cap and intake?
    Kemmerer, Wyoming
    you need to drill a hole in the oil cap, then glue a nipple in the hole, then put a 1 way check valve inline inside a vacuum line, and connect the vacuum line someplace on the throttle body. I used the evap line on the throttle body.
  3. #3 Re: How do you run pcv through oil cap and intake?
  1. Replies: 33
    Last Post: 05-11-2015, 06:21 PM
  2. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  3. Replies: 2
    Last Post: 03-31-2012, 07:49 PM
  4. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
