Thread: pulley belt from zzp
Results 1 to 9 of 9
  1. #1 pulley belt from zzp
    chicago
    i bought a belt from zzp and after it arrived i noticed it was a napa belt. i never like anything made by napa, but is napa a good belt? i always used gatorback.
  2. #2 Re: pulley belt from zzp
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    I did the same thing last spring. I installed the belt and never had any trouble with. I only had it on for a couple months though. I thought I read somewhere that the gatorbacks caused slipping issues?
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  3. #3 Re: pulley belt from zzp
    SE Level Member snow99dohc's Avatar
    Rugby ND The Center of Nor. Amer.
    I had a gatorback with a 3.4 with no problems since andrew and I installed it this summer.
    2003 Pontiac Gran Prix GTP-Thrasher CAI, 180 degree t-stat, AL 104's, ZZP/PT Pcm, ZZP Stg 1 HV TB, ZZP headers, 3'' custom catback, magnaflow mufflers, 3.4''
  4. #4 Re: pulley belt from zzp
    New Salem, ND
    Quote Originally Posted by snow99dohc View Post
    I guess I meant on smaller pulley's, like 3.0 on down. I have a gatorback on my accessories and don't have any troubles either.
  5. #5 Re: pulley belt from zzp
    PA
    For the supercharger belt, gatorback is not favorable. Many people have had many problems when running a smaller pulley and a gatorback belt. They work fine for the accessory side, but they tend to slip sooner on the SC pulley.
    As for good belt, most consider the NAPA/Gates belt to be one of the best. I run the Gates belt and they work great. I wouldn't worry about it at all.
    2001 GSE
  6. #6 Re: pulley belt from zzp
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Ran both when I had a 3.0 with no problems. IIRC it's under the 2.8 that you may have a problems, but this one of those doesn't really matter things. Luckily the belts are cheap enough, if one doesn't work out for you try the other.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  7. #7 Re: pulley belt from zzp
    Saraland Alabama
    NAPA belts are gates (napa doesn't make anything they just sell it with their logo on it)
  8. #8 Re: pulley belt from zzp
    chicago
    thanks for the info! since most of you guys don't have problem with must be good then.
  9. #9 Re: pulley belt from zzp
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    napa belts FTW!!!
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  1. Drive Belt Idler Pulley Replacement [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 06-20-2014, 05:07 PM
  2. Serpentine Belt Size's [*]
    By WasteU in forum How To Write-Ups/Tech Tips
    Last Post: 11-08-2013, 03:31 AM
  3. Drive Belt Replacement [*]
    Last Post: 05-24-2009, 05:44 PM
  4. Drive Belt Tensioner Replacement [*]
    Last Post: 01-03-2008, 10:54 PM
