for 50 bucks I would go get it, even if it doesn't fit, which it probably won't, you should be able to resell it at a decent profit.
My brother in law has a van worse case scenario ill toss him a couple bucks for gas. On a side not I put a second hose clamp on my busted fuel line and tightened the p*ss out of it and then I rtvd where the rubber hose and nylon meet. When in doubt rtv that sh*t!
Sent from my LG-H918 using Tapatalk
Dude f*cking ahole has a picture of an an sd hood on offer up and I get down there and its a 40th anniversary hood. Like seriously man wtf. Id still be interested but the paint is completely trash to. Now we know why he would take 50$ for it
****ing twat waffle.
Sent from my SM-G920W8 using Tapatalk
So the original problem of hesitation during acceleration and misfires is back but now its only on cylinder 4 mostly and a little bit of cylinder 2. Everything is pretty much new since I installed the intercooler I put new plugs in, new plug wires is what fixed this problem the first time but I'm just wondering how likely it is that the brand new wires I got are already bad. Ughhh my wideband is also reading lean during wot I'm seeing 12.5-13.x
Try swapping plug wires. Maybe you cracked the spark plugs. Swap them around to. Of you still have that issue, maybe fuel injectors are clogged/ dirty. Might even be worth swapping coil packs around.
I already swapped the wires and the plugs with no change. Problem is still the same. Runs totally normal then when getting past 60-70% throttle will start cutting out/bogging and misfires will show on 4 and 2. Fuel injectors also have maybe 5k miles and were cleaned a couple hundred miles ago when the intercooler went on.
More throttle; mo problems.
Converter.
Try switching back to just a regular oil cap. See if that solves the issue.
Yeah, you can't run a breather if your pcv isn't plugged.
I mean you can.
It's just garbage lol
if you do a google search for engine code P0300, it will come up with a list of items that can cause a random misfire. I guarantee a vacuum leak will be on there.
