Thread: Bad valve seals?
Results 1 to 20 of 22
  1. #1 Bad valve seals?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Noticed after sitting at a light when I took off smoke came from the back noticed it probably 3 times over 2 months. Got back and parked no smoke while driving or when you get on it then I let it idle for a couple min and hit the gas and it smoked. I had ZZP valve seals installed. Kinda wishing I went felpro now.
    Sent from my SM-S902L using Tapatalk
    2012 F150 STX
    - Gonna be a race truck
  2. #2 Re: Bad valve seals?
    Apr 2012
    Dayton, OH
    I wouldn't think the motor is hurt because it doesn't smoke constantly?
    2012 F150 STX
  3. #3 Re: Bad valve seals?
    Mar 2017
    Internet
    Guess what ZZP valve seals are... yup, they are.
    You could pull the valve covers and look to see if all your seals are still in place. In theory.. you might be able to reseat a seal if it's up a bit without pulling the spring.
  4. #4 Re: Bad valve seals?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    I've put on Felpro, ZZP, crap brand from Advance and Rockauto. When I first found out I had every exhaust seal pop off.
    I haven't pulled my covers in over a year but I'm assuming it's #4 in the back since that's the one that happened last time. it might be how my PCV was setup. I had it blocked on the Gen V and on the Tb on the back end. I have since fixed that but haven't changed the seal yet.
    Mine still puffs every now and then. Probably burn a quart of oil in between changes. Not enough for me to care.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  5. #5 Re: Bad valve seals?
    Apr 2012
    Dayton, OH
    Yeah my PCV should be fully working. Ed's TB adapater with the PCV port on the adapter so it should be working. I might replace the valve regardless anyway to be sure.
    2012 F150 STX
  6. #6 Re: Bad valve seals?
    Donating Users
    Kansas City
    Way to go, Kylie
    2012 Buick Regal Premium1 Turbo - White Diamond Tri-coat - 20% Tint - 5k HID Head/Fog Lights - ZZP CAI
  7. #7 Re: Bad valve seals?
    Nov 2011
    NY
    Consuming oil? How do you know the smoke was oil? What about coolant? Losing any?
    I'd Compression test if losing oil...
  8. #8 Re: Bad valve seals?
    Donating Users
    Kansas City
    But anyways.
    Ryan's car did that.
    The seats weren't installed correctly or flush.
    Had to redo them. Pumped up the cylinder with an air compressor and used a VSR tool to obviously remove the spring/retainer and swapped out the seals for Felpro's.
  9. #9 Re: Bad valve seals?
    Enfield, CT
    Kyle, next time go with Victor Reinz valve seals. Their intake and exhaust valve seals are different and match OE spec. Other companies use generic spec BS cause they don't wanna make 2 different seals because want to reduce cost.
    Remember, the Dana Corp, who owns Victor Reinz, re-designed the LIM gaskets for the 3800, and they are called the AC Delco metal/aluminum gaskets.
    Vic Reinz makes awesome gaskets for so many motors. Yes, everybody believes feel-pro is god cause they make gaskets for every motor but not everything they make is good or higher quality.
    Sent from my VS995 using Tapatalk
  10. #10 Re: Bad valve seals?
    Apr 2012
    Dayton, OH
    I forgot about vic gaskets, I'll have to look into those.
    Luckily my mom is giving me her old car so I can drive something else while I take slowkar to Smuts house to get fixed.
    2012 F150 STX
  11. #11 Re: Bad valve seals?
    Enfield, CT
    Also, when you install the valve seals, don't push too hard.
  12. #12 Re: Bad valve seals?
    Mar 2017
    Internet
    On the fel pro's ... which come with an install sleeve so you don't mess them up going over the valve stem, I use a 1/4" 10mm socket to drive them and tap lightly with a rubber mallet.
  13. #13 Re: Bad valve seals?
    Apr 2012
    Dayton, OH
    Well I finally got the valve seals ordered. Just have room wait to get the car to Smuts house.
    2012 F150 STX
  14. #14 Re: Bad valve seals?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    I ordered a pair of orange Fel-Pro's like that off RockAuto, and they were horrible. They were so loose that you could see a physical gap between the seal and valve stem. I bought a different pair from Advance Auto I believe, and they were blue and fit perfect.
  15. #15 Re: Bad valve seals?
    Apr 2012
    Dayton, OH
    God dammit lol
    I was kinda surprised they weren't blue. I'll have dan try these if they don't look like they work I'll have to get another brand. I was gonna have him try to reseat a seal if one came up
    2012 F150 STX
  16. #16 Re: Bad valve seals?
    Nov 2011
    NY
    The victor reins are tighter going on and sit a bit higher on the pedestal. Is all good unless you're going crazy lift. The Blue ones are the Viton Seals.
  17. #17 Re: Bad valve seals?
    Apr 2012
    Dayton, OH
    I have 1.9 rockers if it matters, I'm gonna order some VR ones. Those felpros were listed as the blue ones and with rockauto ****ty return thing it's not worth trying to get my money back.
    2012 F150 STX
  18. #18 Re: Bad valve seals?
    Apr 2012
    Dayton, OH
    Before I email them anyone know the difference between the two VR ones besides the intake/exhaust obviously.
    2012 F150 STX
  19. #19 Re: Bad valve seals?
    Apr 2012
    Dayton, OH
    Oh I'm dumbass I'm pretty sure it's a set vs each. It shows they are made of FKM but I think a quick Google shows that's another term for viton
    2012 F150 STX
  20. #20 Re: Bad valve seals?
    Apr 2012
    Dayton, OH
    BTW the orange ones are still Viton according to the box. I don't think the color directly dictates material tho. Got another set ordered just in case tho of the VR
    2012 F150 STX
  1. Valve Seals and Modded Retainers for s1X
    By Jomamma in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2015, 12:38 AM
  2. Are these valve seals the same?
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2015, 05:33 PM
  3. Valve stem seals
    By bachert24 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-05-2015, 03:45 PM
  4. WTB: 3.4 Pulley, Valve Seals, Retainers
    By DanPrixGTP in forum Wanted To Buy - Parts
    Last Post: 02-03-2014, 08:55 AM
  5. Fel-Pro Premium Valve Stem Seals-Anyone use them?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2008, 07:50 PM
