Thread: Resevoir for intercooler?
Page 3 of 10 FirstFirst 12345 ... LastLast
Results 41 to 60 of 192
  1. #41 Re: Resevoir for intercooler?
    Quote Originally Posted by suitercrew View Post
    Why does an intercooler lower boost?
    Sent from my LG-H918 using Tapatalk
    this mostly applies when you have a ported lim, it opens up that blower hole to double its size almost.
    plastic elbows are ok to use.
  2. #42 Re: Resevoir for intercooler?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    So it doesnt really provide any benefits though does it? Generally lower boost would be a good thing, but if its just lower because you made the lim bigger then it's not really beneficial right?
  3. #43 Re: Resevoir for intercooler?
    on a 2.8 im only hitting 12 ish.
    the 3.2 i made 9 ish, but i also have rockers and ported heads. the heads alone dropped me a lb of boost.
    and your a top swap too are you not? if so all the boost in the world is not your friend at all.
  4. #44 Re: Resevoir for intercooler?
    Kemmerer, Wyoming
    Volumetric efficiency is the ability of the engine to take in air. a bigger hole in the lower intake manifold increases the engines volumetric's efficiency, so while there isn't as much boost, the engine can get more air, which will make more power. the whole purpose of a supercharger is to move air into the engine, so by making the hole bigger in which the supercharger can push air, more power will be made.
  5. #45 Re: Resevoir for intercooler?
    Oct 2015
    Ya I'm topswapped currently rockers,headers,e85,3.3.
    I just thinks its weird if the ported lim lowered boost that much I would think it would be a really good mod for everyone to do, even non intercooled people.
  6. #46 Re: Resevoir for intercooler?
    you'd best start looking for a 2.8 pulley now. cause you can run it for sure on corn.
  7. #47 Re: Resevoir for intercooler?
    Kemmerer, Wyoming
    and it is a good mod, but people usually don't bother unless they do a gen 5 swap.
  8. #48 Re: Resevoir for intercooler?
    Oct 2015
    Ya I'm running the 3.3 with stock timing I was thinking of getting a 3.0 and bumping timing to 19* but maybe ill get a 2.9. Now i just have to mod my lim for pcv function or get a breather.
  9. #49 Re: Resevoir for intercooler?
    what ya waiting for on that timing? turn it up now......
  10. #50 Re: Resevoir for intercooler?
    Kemmerer, Wyoming
    he isn't actually running E85, it's more like E50, if I remember what he said earlier is accurate.
  11. #51 Re: Resevoir for intercooler?
    Oct 2015
    Quote Originally Posted by SgtMarshal View Post
    You are correct its supposedly e54 and ya I'm pretty maxed timing wise on the 3.3 if I had to guess I bet I could raise timing to 18* and be fine kr wise but I've been to busy to redo the tune just to potentially gain 5hp. Especially when I will have to redo it again in two weeks when the intercooler goes on.
  12. #52 Re: Resevoir for intercooler?
    au contraire,,,, 3 or 4 more degrees at wot is way more then 5 hp on the butt dyno.
    grab a comp g bin and take its timing files. thats what im running now, and its way better then what i had before. i did knock the timing down some at wot so i hit 17.
  13. #53 Re: Resevoir for intercooler?
    Oct 2015
    Ya I remember when I was on a 3.5 and going from stock timing to 18* made a big difference. The car just seemed to run a lot stronger, but either way it runs good enough now that I'm not gonna mess with it until the intercooler and big power comes!
    Scotty did you still use 3/4" hose on the core itself despite the barbs being around .6"
  14. #54 Re: Resevoir for intercooler?
    i got the ic thats sold here, hoses went on snug from what i remember.
  15. #55 Re: Resevoir for intercooler?
    Oct 2015
    Stupid zzp lol. I wanted to get the phenolic core but ended up getting a core, he, pump, and some misc items shipped from canada for 100$ cheaper then just the phenolic core so yaa
  16. #56 Re: Resevoir for intercooler?
    Oct 2015
    Has anyone ever ran dual heat exchangers?
  17. #57 Re: Resevoir for intercooler?
    what fmhe you have? if its a 4 inch thick one, where you putting #2?
    mine has yet to be hotter feeling then ambient temps.
    but them thin ones will get warm to hot even.
  18. #58 Re: Resevoir for intercooler?
    Oct 2015
    Its almost 3" thick I believe its the zzp one. I hadn't really thought about it, I was just curious if anyone had
  19. #59 Re: Resevoir for intercooler?
    when you see just how much room you dont have to work with, you'll then know why its never done.
  20. #60 Re: Resevoir for intercooler?
    Oct 2015
    Fair enough lol
  1. Washer resevoir
    By mthorn11 in forum Visual/Body Modifications
    Last Post: 02-15-2013, 03:03 PM
  2. oil in coolant resevoir
    By rdfenn3 in forum General Grand Prix Discussion
    Last Post: 11-12-2012, 01:59 PM
  3. Where is my power steering resevoir?
    By i3abydoll in forum General Tech Discussion
    Last Post: 09-12-2010, 10:42 AM
