Has anyone had this problem with the lights on, i want to know what is the cause how to how get the light off. I got my tire pressure light to go off. any clues
you got radio controls in th esteering wheel? they work if you do? if they dont work you need a clock spring. other then that, any yellow wires under the seat or under the dash open the plug and close it a few times.
the air bag module is under the front pass seat, and under the carpet, its the box in the carpet it gets wet and corrodes at its screws and inside as well. but once again, work that plug, clean its mounting area.
if none of that works get it scanned.
low coolant light is a bad or dirty sensor in the rad if you take the pass headlight out you should be able to see it and reach it. the easy way out here is to just unplug it, the light will go out and never come on again. so check your coolant every now and then to be safe if you unplug it.
