Thread: L32 LIM Gasket Question
Results 1 to 2 of 2
  1. #1 L32 LIM Gasket Question
    SE Level Member Moozery's Avatar
    Apr 2016
    Ontario
    Sorry if this has been asked, I searched for a while with no luck.
    I've been trying to get info on 3800 LIM gasket changes to prepare for changing mine on my 04 GTP with an L32 series III. Problem is, I can only seem to find info and walkthroughs for series II engines.
    I'm just trying to figure out if/what steps change from the series II to the series III, and what different gaskets and parts are required.
    So far this is my parts list:
    - Aluminum LIM Gaskets
    - S/C Gasket
    - Thermostat Housing Gasket & O Ring
    - Valve cover gaskets
    - Aluminum coolant elbows
    - ACDelco RTV
    - Coolant, oil, filter, thermostat
    Now I just put brand new injectors in only a few weeks ago so I wasn't worried about the O rings on those (should I?)
    If anyone has any specific gasket models to recommend, or good walkthroughs, extra parts, etc, it'd be greatly appreciated.
    I was planning to get almost all of the above parts from ZZPerformance unless it's advised against getting there.
    Pre-Production 2004 GP GTP Comp G / 91,000mi / TransGo Shift Kit, Spectre Open Cone, 180 Tstat, AL605's, ZZP 3" catted DP, ZZP front PLog, Intense PCM, GMPP Sway Bar
    Access Old "How-To" Links
  2. #2 Re: L32 LIM Gasket Question
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    The procedure is literally the exact same between a L67 and L32. Don't forget thread sealant for the LIM bolts, other than that you're good to go.
  1. LIM gasket question
    By Jakegday in forum General Tech Discussion
    Last Post: 08-15-2012, 07:04 AM
  2. GM S/C Gasket Question
    By acidcrashdburnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2012, 07:13 AM
  3. lim gasket question
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-21-2012, 05:57 AM
  4. LIM Gasket Question
    By zackp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2012, 07:23 PM
  5. 98 L36 LIM gasket question
    By IffyG in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2011, 07:13 PM
