Thread: High knock-runs like crap.
Page 1 of 3 123 LastLast
Results 1 to 20 of 48
  1. #1 High knock-runs like crap.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Well I have switched my 04 comp G back to gas from e85. Something is very wrong and I can't figure it out. It has constantly high knock. At one point it pinned out at 14.9* and wouldn't change. There is knock at idle, cruise, and high throttle. There is no check engine light. it sputters at light throttle and seems to have power at full throttle. the opposite of what it was doing on e85. Before I switched to e85 the car ran perfect.
    Here is what I tried and or replaced recently. the problem existed before and after these changes.
    Put on brand new Delco stock injectors.
    Put on autolite copper 104 copper plugs
    Put on the 3.4 pulley.
    I pulled the supercharger belt to see if the supercharger was causing knock and it was not. the knock was still there.
    Any ideas of what I should look for?? I am at a loss. The car ran so good before I changed over. so something with the e85 messed something up
    here is a scan from HPT.
    https://www.dropbox.com/s/nojf71bo5p...20bad.hpl?dl=0
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: High knock-runs like crap.
    May 2008
    Schuyler, NE
    Have you checked your fuel pressure?
  3. #3 Re: High knock-runs like crap.
    Nov 2011
    NY
    Agree, check pressure, the e85 tends to clean out the tank and lines, something could be clogged, ie, fuel line, filter, etc.
    Your sig says Overkill tune, was the tune adjusted for e85?
    Before I switched to E85 the car ran perfect!
    Sucks right? Is a Pontiac, you never know what you'll get when you play... Lol
  4. #4 Re: High knock-runs like crap.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    The pressure is holding at 58 psi
    yes the overkill was adjusted for E85 by me and the help of the guys here. I have a HPT pro tuner.
    ... yeah it sucks. I messed up a great running car.
  5. #5 Re: High knock-runs like crap.
    did you not make a copy of the original tune to save ?
  6. #6 Re: High knock-runs like crap.
    May 2008
    Schuyler, NE
    Can you take a scan of the car running and send it to me?
  7. #7 Re: High knock-runs like crap.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    There is a scan attached from drop box in the first post. If you want me to send it in email just pm me your email address.
    Scottydoggs- yes I saved my original overkill tune several times and kept them safe.
  8. #8 Re: High knock-runs like crap.
    if your back on your good tune id say its not the tune, or the corn's tune, something went wrong with the engine, maybe the blower is now shot? if its got kr in park when revved thats where id start.
    take the sc belt off and jump on it, if no kr, im back at the blower being bad. seen this in person, was fighting this guys tune, then im like lets see wtf happens when revved in park, 2º kr. took the belt off, no kr at all. he was was getting up to 9º kr when he got on it too. no matter what his timing was, high or cut to 9º.
  9. #9 Re: High knock-runs like crap.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I did take the supercharger belt off and nothing changed. It had knock at idle and while revving while off.
    I'm going to have to make an appointment for the dealer to diagnose. If it's something major I'll probably part it out.
  10. #10 Re: High knock-runs like crap.
    thats not good at all. try both belts off?
  11. #11 Re: High knock-runs like crap.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Yeah I have a feeling something internal broke. I have not tried with both belts off yet.
  12. #12 Re: High knock-runs like crap.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Curious, what would both belts off eliminate?
    I took it to a reputable GM dealer and they did not find the problem. The service advisor said that their best guess was either a Maf sensor but those usually will throw a code or a PCM. So now I'm stuck at square 1.
    Any guesses on what I should check next. The issues are surging/bogging, high knock, and random cylinders misfiring. None of this is turning on the Engine light!! Any help is greatly appreciated
  13. #13 Re: High knock-runs like crap.
    have you scanned for pending codes? drive it around, dont turn it off, then scan it running still. might have one hiding on you.
    could be a beat maf, sometimes they dont set a code. if you got a junk yard local see if you can find one there.
  14. #14 Re: High knock-runs like crap.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Yes, no pending codes which baffles me because it runs like crap and shows the knock and misfires. It sounds like all the dealer did was put it on the tech II. I thought I seen a way to bypass the maf. Something like VE tune??? Can that be done to check the maf?
  15. #15 Re: High knock-runs like crap.
    Mar 2017
    Internet
    Read the tune on the car. Don't look at what you loaded, actually read the tune off the car. Check that your expected changes took.
    That would be my starting point as long as the car ran good on E85.
  16. #16 Re: High knock-runs like crap.
    Mar 2017
    Internet
    Also.. scan the car.. is it running super rich like you tune for E85? You said you have HP Pro.. which means you have all the tools to see a possible tune related issue. It's tough to believe that it was running perfectly, you put in gasoline vs e85, tuned it back for the fuel and it's all of a sudden running poorly.
    To me that screams tune or something that you had to change to get to E85 and forgot to change back.
  17. #17 Re: High knock-runs like crap.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    It didn't run good on e85. It ran good in normal driving on e85 but bad at wot or high rpm. But it had nowhere near the knock or misfires it has now. I will read the pcm and see what it says. I saved the overkill gas tune in a separate place so I didn't change it. But definitely worth a try. I don't have a wideband so a little limited. I think it is running lean, around 16%.
    Thanks
  18. #18 Re: High knock-runs like crap.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I checked the tune and compared it with the old good one and they are exact. The maf frequency is reading where it normally did. It is running lean with the maf and I unplugged it and it went very rich. With the maf unplugged it seemed like it wanted to stall every so often but didn't. When unplugged it had a pending code of p0102 which was expected. No other codes pending. I guess I will try a compression test this weekend to see what that shows.
  19. #19 Re: High knock-runs like crap.
    May 2008
    Schuyler, NE
    Try scanning for misfires on individual cylinders to see if it picks up any.
  20. #20 Re: High knock-runs like crap.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    it does pick them up mostly on 3-4-5-6. Usually 2-6 misfires per refresh
  1. Help! new to site and grand prix's car runs like crap!
    By RuderGTP in forum General Tech Discussion
    Last Post: 04-26-2013, 09:39 AM
  2. 99 GT temp gauge runs high
    By Harley79 in forum General Tech Discussion
    Last Post: 02-08-2013, 04:44 PM
  3. Hi my car runs like crap!
    By Nick03gpgt in forum Introductions/Noob Questions
    Last Post: 12-21-2012, 03:58 PM
  4. New lateral rod; Car runs crap
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-06-2010, 02:26 PM
  5. Engine runs like crap!
    By kfish in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-18-2009, 02:26 AM
