Thread: FWD to AWD help
Results 1 to 16 of 16
  1. #1 FWD to AWD help
    Jan 2017
    Washington
    First off before I start this post, I don't care about the cost and time it'll take to accomplish this project. It's my fun little project that I want to do. I want to convert my 2000 GTP to AWD or RWD. Would it be easier to buy a chassis of a AWD or RWD car and put the shell of my GTP onto it and make custom mounts?
    If I wanted to make it to a manual could I hook up a manual transmission to the stock GTP engine or would I have to swap out both of them?
    I'm just getting into working on cars and I thought this would be fun to do so I can learn things about it, I've done some searching and most of the answers are, it's a waste of time and money. But I don't care, I plan on keeping it for a long time.
  2. #2 Re: FWD to AWD help
    how this, good luck... one guys done it, it was silly great. your not him if your asking how to do it. and 50 others dreamed about it. so you will likely fall into the #51 spot.
    enjoy and drool over it.
  3. #3 Re: FWD to AWD help
    Jan 2015
    United States
    Hopefully you enjoy fab work because this will involve a crap ton of it. The GTP is basically a unibody so there would be a bunch of cutting to convert to RWD. So if I were you I would body swap it onto a donor AWD or RWD chassis/floorpan.
  4. #4 Re: FWD to AWD help
    May 2008
    Schuyler, NE
  5. #5 Re: FWD to AWD help
    Jan 2014
    AR
    I feel like the simplest way to go about it is to buy a 4th gen Camaro that has V6 and manual trans. Pull them both into the shop and don't come out until you've made a Camaro with an L67 that looks like a GP. The build in that link is cool, and also performance oriented. You trying to go fast with this?
  6. #6 Re: FWD to AWD help
    SWPA
    You posted 2 months ago that you are "just starting to become a mechanic." That alone tells me you don't have the fab skills to pull this off.
  7. #7 Re: FWD to AWD help
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Most experienced mechanics don't have the skills for a job like this.
    Just drive it like you stole it and start saving for a WRX.
    GPONA #1 Cyber Bully
  8. #8 Re: FWD to AWD help
    GTP Level Member buickman104's Avatar
    NYC
    You pretty much have to re-engineer the whole car.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  9. #9 Re: FWD to AWD help
    hangover park IL
    Quote Originally Posted by buickman104 View Post
    this
    ~James~ Psychotic Gearhead
  10. #10 Re: FWD to AWD help
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Just flush your money down the toilet now and save yourself the time. Or give it to us...
    Either way, it ain't happening. No amount of you tough talking on the Internet will make us believe it either.
    Beginner mechanic my ass.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  11. #11 Re: FWD to AWD help
    hangover park IL
    Quote Originally Posted by Ryan97Rut View Post
    good, we have just over 20 years in our 4wd cutlass
    probably easier to toss your engine into an aztek or transplanting a awd 4t65e drivetrain into it
    swapping the awesome 3800 into something rwd would be the best since your able to use a conventional trans and a lot of off the shelf parts
    its some std 5spd F body 3800 parts/60* v6 bellhousing, you could drop a full boogie 6 spd even
    we're on our 3rd chassis/iteration, lots of stuff we've had to learn first hand with the packaging/suspension
    one of the all time greatest projects ive ever seen, that car is proof of what splitting the pan/firewall at the pinch welds and putting a shell on is sweet happiness.
  12. #12 Re: FWD to AWD help
    Jun 2017
    Alberta
    Just saw this post. God damn that c1irst guy o1s actually nuts. I mean its pretty simple his design. But all two engines, no wonder he needs 1200 hp. First guys design would be much easier. I mean if you were going to do that. Move the engine from the frong to the back. Bam all the same parts but custom mounts. The domain guy though, knows how to lay some bead.. my advice to OP. Wait a few years. Your going to start attempting any of those and actully just have a pile of scrap metal with wheels. Dont know the time frame for the second domain car guy. **** ton of work for 1 year though.
    Sent from my SM-G920W8 using Tapatalk
  13. #13 Re: FWD to AWD help
    May 2016
    Burns City, Indiana
    Another thought would be Syclone/Typhoon chassis, mod/adapt 3800 to trans/transfer case combo shorten and narrow as needed and set body down on it.
    BUT scarce, and lots of modifying.
  14. #14 Re: FWD to AWD help
    May 2016
    Burns City, Indiana
    So if your serious, there is only one way to do this with least amount of issues.
    I would look around for an AWD 4t65E, then go about making it function in the car. Knowing the trans ratio is critical also so some research will be needed. And hopefully finding one with same as your GTP is possible or it can be modified to do so.
    Now to facilitate this your going to have to make the exhaust tunnel bigger, modify fuel tank/system to clear and honestly I would look at 89-94 Tbird IRS. It can be had in 8.8in which is super strong.
    The rear suspension will require a lot of mods as your going to need hubs that accept axles. havent looked to see if any of the GM hubs would interchange.
    Boxing, reinforcing and adding in appropriate mounting for said rear suspension.
    The only other CHEAP thought would be reinforcing where rear lower arms mount, and building from SAY an S10 rear axle. Cutting, welding and reinforcing an upper control arm cross member would be fairly easy. If you have appropriate width rear axle remaking the rear struts into coil overs. Just take some machine work and proper mounting.
    Third possibility is adding in a leaf sprung suspension. Measuring from either lower control arms mounts or the sub at the rockerbox, to centerline of rear wheels. This would give you basic numbers then double the length. Your spring can have a slight amount longer to the rear and this would even make it ride bit better. Leaf springs are dependent on multiple leafs. BUT you need to bone up on suspension design read this ,https://www.amazon.com/How-Make-Your.../dp/0912656468
    Biggest issue is packaging and amount you want to modify. You may even be able to use rear drive from a Rendezvous.
  15. #15 Re: FWD to AWD help
    I break stuff selliott's Avatar
    Kansas City
    Here is the sad truth, if you have to ask how to do the awd or rwd conversion your not ready to do it. I'm not trying to be a dick but of all the members in this forum I would bet I could count on one hand the people who have pulled it off one of them being James (turbocharged400sbc) and as someone who has way to much money in a Gp I would advise you to go in a different direction. But I could be wrong, it happens alot
  16. #16 Re: FWD to AWD help
    hangover park IL
    Sellout is correctamundo
