Thread: 98 gtp boost reading
Results 1 to 20 of 26
  1. #1 98 gtp boost reading
    SE Level Member Moriarity81's Avatar
    Aug 2011
    Michigan
    i recently bought a 98 gtp it has pillar guages one being a boost/vacume guage when im just crusin alon the vacume reads almost 20 and when i put it to the mat it climbs up to 0? i looked up videos on youtube and watched all these videos of stock gtps pushing like 10psi is something up with mine? i dont know much about superchargers other than they give ur engine a little extra boost for acceleration so any info on how i can get my boost level up would be awsome
  2. #2 Re: 98 gtp boost reading
    Grand Island, Nebraska
    does your car feel slow? you may have a boost/vac leak.
    EDIT: what does the little boost gauge in the DIC say? (if you have one)
  3. #3 Re: 98 gtp boost reading
    Charles City, IA
    Where do you have the lined hooked up at? I bet you hooked it up wrong. Needs to be on the line going to the map sensor.
    SMGPFC Two Nipple General
  4. #4 Re: 98 gtp boost reading
    This ^ is probably it, but he also didnt hook it up, he bought it that way.
  5. #5 Re: 98 gtp boost reading
    If the gauge line is hooked up on top of the supercharger, that's the issue.
  6. #6 Re: 98 gtp boost reading
    Aug 2011
    Michigan
    im not sure where its hooked up at i bought the car with it installed already and idk cant really say its faster than the 4 cylinder ranger i had lol but the boost guage on the DIC says like maybe halfway. i do notice that it kinda starts up hard like cranks over slightly as soon as u turn the key dies out right away then fires idk if a vacume leak would cause that or not?
  7. #7 Re: 98 gtp boost reading
    Aug 2011
    Michigan
    where is the map sensor located? i can go check it real quick
  8. #8 Re: 98 gtp boost reading
    It is in the back of the engine, its bolted onto the supercharger. there is a little nipple on the botton where a vacuum hose goes and then that hose goes under the supercharger snout, and then to the fuel rail. there should be a tap into that somewhere.
  9. #9 Re: 98 gtp boost reading
    Aug 2011
    Michigan
    alright ill go take a look at it and let ya know what i find out
  10. #10 Re: 98 gtp boost reading
    Charles City, IA
    take pictures and it sounds like you have a bad boost bypass valve for the half boost issue.
  11. #11 Re: 98 gtp boost reading
    Aug 2011
    Michigan
    Alright ill post sometime tommorow when i get some time and post them
  12. #12 Re: 98 gtp boost reading
    utah
    If it snaps straight to zero its hooked up wrong...the vac tree has a check valve..guessing that's where its kooked into. And I second the bbv on the half boost issue. Any other mods or just gauges? And what other gauges is it running?
  13. #13 Re: 98 gtp boost reading
    Charles City, IA
    There is no check valve in the vac tree, its just pre rotors so the air is not going to be compressed.
  14. #14 Re: 98 gtp boost reading
    Aug 2011
    Michigan
    only a cold air intake but its got a fuel air mixture guage, booost guage, and i believe a temp guage
  15. #15 Re: 98 gtp boost reading
    SE Level Member 97PAGTP's Avatar
    May 2011
    Williamsport, PA
    Anyone have pictures where the T should go for the boost gauge? I am having the same issue.
    1997 Dark Teal GTP coupe, Magnaflow highflow cat, Borla mufflers w/ Magnaflow tips, Wizaired, LS1 crossed drilled/slotted fronts, stock crossed drilled/slotted rears, tinted tails, clear corners, triple pod w/ Glowshift gauges, STB, chrome grilles, junk transmission, 200k+ miles...
  16. #16 Re: 98 gtp boost reading
    Houston
    Quote Originally Posted by 97PAGTP View Post
    Right here....between the T under the snout and the MAP
  17. #17 Re: 98 gtp boost reading
    utah
    right underneath the blower snout is a T...thats it
  18. #18 Re: 98 gtp boost reading
    May 2011
    Williamsport, PA
    Cool, thanks
  19. #19 Re: 98 gtp boost reading
    Dec 2010
    DMV
    Love the blue hoses, where can I buy?
  20. #20 Re: 98 gtp boost reading
    Houston
    This is where I got mine
    Silicone Hose Kits - 7 colors
  1. stock boost gauge not reading
    By mtz956 in forum General Tech Discussion
    Last Post: 10-14-2010, 08:29 AM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. No boost reading..
    By black98gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-27-2009, 07:53 PM
  4. Factory Boost Gauge reading
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2009, 02:50 PM
  5. MAP reading
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2009, 12:34 AM
