Thread: How much Vac
Results 1 to 18 of 18
  1. #1 How much Vac
    Donating Users fratzke7's Avatar
    Waterloo, IA
    Just wondering with the mods in my sig what my gauge should be reading at idle for vacuum?
    ZZP 3.1 MPS, 2.5" catless exhaust, TOG's, XP hot cam, 105# springs and mod'd retainers, ZZP pcm, alt voltage booster, Wizaired intake, heads lightly ported and 3 angle valve job, PRJ 10.4's, ummm
  2. #2 Re: How much boost then??!!
    Waterloo, IA
    Ok well how much boost should I have then with my mods??
  3. #3 Re: How much Vac
    not sure about vacuum, but with that cam and pulley you shouldnt see much over 12 psi or so for boost. you dont want to run much more than 13 seeing as how our MAP sensors only read up to 14.7 psi (2 bar).
  4. #4 Re: How much Vac
    Waterloo, IA
    Ok so where can I get a new map sensor that reads higher!?
  5. #5 Re: How much Vac
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by fratzke7 View Post
    You could get a MAP sensor that could read higher, but you would have to modify the computer to be able to interpret that reading, and I don't currently know of any way to do that.
    2001 Buick Regal LS - Almost Stock
  6. #6 Re: How much Vac
    Well...I was running 13 psi with a 3.25"...can you not just upgrade to a 3 bar MAP incase you run over 14.7 psi?
    I have an XP cam too...I run about 20 lbs. of vacuum...hope that helps.
  7. #7 Re: How much Vac
    no, you can run over it for sure, but youll have to tune around the computer not being able to read that it is higher than that. i havent really heard of anyone running a 3 bar map because honestly you shouldnt be running over like 13 psi anyway. if you dont have enough flow mods for it to stay that low then youre probably knocking or running a crappy tune.
  8. #8 Re: How much Vac
    Reason being is because I had had touched 15 or 16 on a cold day with the 3.1" last winter...got a cam and headers...no restrictions in the exhaust...I am just thinking since it was so cold outside but idk...
  9. #9 Re: How much Vac
    why do you want one? how can you be running that much boost and not knock? the m90 gets so enormously inefficient and heat producing past a 2.8 pulley that it would be stupid to run that much. get more flow mods before you run a smaller pulley. you dont want more boost.
    why dont people get that boost is a measure of restriction. hell, if i could stay at the same power level and have enough flow mods to run 5 pounds of boost i would do it.
  10. #10 Re: How much Vac
    Waterloo, IA
    I was only asking for the mere fact that I will be adding much more to my car and am buying things with time
  11. #11 Re: How much Vac
    there is no reason for you to have one. if youre running 16 pounds of boost from an m90 there is something wrong or you dont have enough flow to use the boost correctly.
  12. #12 Re: How much Vac
    Donating Users blowfishRus6's Avatar
    g.a.
    id rather just turn up timing then boost.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  13. #13 Re: How much Vac
    Quote Originally Posted by blowfishRus6 View Post
    so now we got a smart guy, eh?
  14. #14 Re: How much Vac
    g.a.
    happy knob
    its slow.
  15. #15 Re: How much Vac
  16. #16 Re: How much Vac
    g.a.
    i hope to have one soon and to see at what timing/boost levels work the best.
    its slow.
  17. #17 Re: How much Vac
    it is just nice to have one of those instead of having to change your tune to find what the car likes each day. i cant wait to get mine installed and running how it should. i want to go from less than stock timing all the way up to about 20*.
  18. #18 Re: How much Vac
    g.a.
    yea i know. some days it might could use some more, some days it might could use a little less. it would be nice to do it on the fly.
    it would really come in handy at the track.
    its slow.
vac
