Thread: Cheap Low miles 3.8 engine
Results 1 to 14 of 14
  1. #1 Cheap Low miles 3.8 engine
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    Hey I found a 3800 supercharged engine with low miles. It have the full harness and computer for 200. Would it be a good idea to install it in my 97 grand prize GT?
    Sent from my SM-N920T using Tapatalk
  2. #2 Re: Cheap Low miles 3.8 engine
    GT Level Member Nitvid's Avatar
    Jul 2013
    Belleville
    I just paid $300 (plus an additional $110 for shipping) for an S/C engine with 100k miles on it to put into my 99 GT. the yard apes at the junk yard cut the harness, but it had the ends I needed to make it work.
  3. #3 Re: Cheap Low miles 3.8 engine
    Sep 2014
    New Orleans
    Wat All did you have to do to put it in because it have the harness and computer with it and i already have my old engine out of my car
  4. #4 Re: Cheap Low miles 3.8 engine
    Jul 2013
    Belleville
  5. #5 Re: Cheap Low miles 3.8 engine
    Quincy, Mass
    Do some more research before you jump on it. 97 GPs use the 4t60e trans which uses vacuum, 98+ don't, not a big issue. The Pcm on 97s are also a little different, same connectors but I believe you need to use a 97 pcm, one from a gtp would work but you'll need to program it for the gt trans. There's probably a few things I'm missing.
    It can be done it's just not as simple as dropping it in and plugging in the Pcm. If you get a 97 gtp motor, trans, Pcm, and harness then it would be that simple.
    No more GP 04 Impala SS Indy:
  6. #6 Re: Cheap Low miles 3.8 engine
    Quote Originally Posted by Jason97GrandprixGT View Post
    depends on what tranny you have if you should sc or not. maybe find the tranny too if need be.
  7. #7 Re: Cheap Low miles 3.8 engine
    Sep 2014
    New Orleans
    Im not worried about the trans going out, my mechanic do a trans Job for 300.
  8. #8 Re: Cheap Low miles 3.8 engine
    Sep 2014
    New Orleans
    Im getting the motor, wire harness and computer. I can get a later year trans when the one that i have go out
  9. #9 Re: Cheap Low miles 3.8 engine
    the pcm wont work for your tranny, it needs to be tuned for that. run a tune for the wrong gears and the tranny eats itself.
  10. #10 Re: Cheap Low miles 3.8 engine
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    A tune is always a good idea anyways.
    Sent from my SM-G920P using Tapatalk
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  11. #11 Re: Cheap Low miles 3.8 engine
    Quincy, Mass
    There's more then $300 in parts to rebuild a tranny, most run $1500-3000
  12. #12 Re: Cheap Low miles 3.8 engine
    Sep 2014
    New Orleans
    I get my tranny from the junkyard for $75 and labor cost be 300
  13. #13 Re: Cheap Low miles 3.8 engine
    Quincy, Mass
    So how many junk trannies have gone through?
  14. #14 Re: Cheap Low miles 3.8 engine
    Sep 2014
    New Orleans
    On my second tranny and Third engine
  1. How Many Miles on your 3.1 Engine and Transmission?
    By jbamonte in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-08-2013, 03:29 PM
