Thread: mysterious exhaust leak
Results 1 to 12 of 12
  1. #1 mysterious exhaust leak
    Kemmerer, Wyoming
    I had a mechanic look at my car the other day and he said I had an exhaust leak. I have felt all around for a leak but can't find anything. I checked all the nuts and bolts on the headers and they are tight. I did tighten the clamps on the crossover, but it was only a small amount, shouldn't have been enough to cause a leak. I saw the mechanic again today, and he said he hoped it wasn't a valve issue.
    I just switched to E85, and I'm wondering if that could cause a sound like an exhaust leak. I don't see how it would, but I'm not a genius.
  2. #2 Re: mysterious exhaust leak
    Quincy, Mass
    Use a stethoscope to hear for the leaks, it could be something you can hear with the naked ear at idle.
    No more GP 04 Impala SS Indy:
  3. #3 Re: mysterious exhaust leak
    Kemmerer, Wyoming
    I wonder if a medical stethoscope is any different than an automotive stethoscope. I started lifting weights with a doctor and a dentist, so I could ask and see if either one has one I can borrow
  4. #4 Re: mysterious exhaust leak
    May 2008
    Schuyler, NE
    Which headers are you running? And what exhaust?
  5. #5 Re: mysterious exhaust leak
    Kemmerer, Wyoming
    SD headers, magnaflow cat converter and stock catback
  6. #6 Re: mysterious exhaust leak
    May 2008
    Schuyler, NE
    Is the flex or v-band leaking?
  7. #7 Re: mysterious exhaust leak
    Kemmerer, Wyoming
    I didn't think about checking the flex. I'm using good solid clamps, and I checked there so that shouldn't be it either. I'll drive the car up on the ramps and see if I can feel along the flex
  8. #8 Re: mysterious exhaust leak
    May 2008
    Schuyler, NE
    Check the vband while you're there too. Pretty much anywhere a pipe connects to another, I've seen them leak.
  9. #9 Re: mysterious exhaust leak
    Buffalo
    Sea foam it. Found I had a leak in my zzp tog doe pipe behind the steel braided mesh. They replaced it for free
  10. #10 Re: mysterious exhaust leak
    Here is what I don't get, you take it to a mechanic and he says you have a leak yet you are still searching for said leak.
    Why would this guy not be able to tell you where it was leaking from?? What kind of guy would just tell someone "hey man, you have a leak in the exhaust", then not even tell them exactly where the leak is from????
    It may be more understandable if you were in for something completely unrelated but even if I was working on someones car I'm not sure I'd even mention it if they didn't seem to care about an issue that was clearly there.
  11. #11 Re: mysterious exhaust leak
    Kemmerer, Wyoming
    the mechanic was looking at something completely different, and to get an actual diagnoses, I probably would have had to pay the 110 dollars an hour the dealership charges.
    I'll try the seafoam once I get the new snout on the car, also considering the smoker method.
  12. #12 Re: mysterious exhaust leak
    Quincy, Mass
    I have a leak where my dp connects to the catback. It's tiny to the point I can't hear it with a stethoscope at idle. I know this because the exhaust shop that put it in told me but can't feel it either. My exhaust also drips water at the connection after the res but they never mentioned a leak there. I'm going to get it all welded up after I get my togs on.
  1. Mysterious Coolant Leak
    By 67mgb in forum Engine
    Last Post: 10-28-2013, 09:35 PM
  2. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  3. Cylinder 6 Misfire and exhaust leak and mysterious wiring connector?
    By Klutch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-04-2012, 11:33 PM
  4. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
