Thread: people with dyno sheets
Results 1 to 13 of 13
  1. #1 people with dyno sheets
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I don't really care about how much HP, but am looking for your powerband. Please list any applicable mods (cam, heads, headers etc) and where you are hitting peak HP. I realize there are going to be differences based on the mod level but it would be interesting to see the powerband. If you have your dyno sheet that would be great as well.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Re: people with dyno sheets
    I live here. UR LOSN's Avatar
    Rockford, IL
    I had a few spikes here and there.....LOL
    sorry, couldnt resist.....
    ok, back on topic
  3. #3 Re: people with dyno sheets
    St Louis MO
    daewoo FTL
    2010 Camaro SS LS3
  4. #4 Re: people with dyno sheets
    GT Level Member bayareagtp's Avatar
    Milpitas , Ca.
    great dyno sheet ! LOL .
    1998 GTP , 3" down pipe w/cat , u-bend delete , full 3" exhaust w/ magnaflows , no resonator , powerslot front rotors , Overkill PCM , Overkill FWI , 180* t-stat , 1* colder plugs , alt. re-wire , alt. stage 1 booster . 215 whp and 238 torque .
  5. #5 Re: people with dyno sheets
    St Louis MO
    ok it was fun but time to quite taking a dump in my thread. and that goes for me too.
    On topic, the couple of posted dyno results I've seen all have tq max at 3000-4000 and HP from 5200-5800 rpm. Mods not available.
    2010 Camaro SS LS3
  6. #6 Re: people with dyno sheets
    SE Level Member x1FastGTPx's Avatar
    Downers Grove
  7. #7 Re: people with dyno sheets
    With that graph, I hope you're running 3.69's or better in the trans!
    Edit:
    Did some quick calculations, and you need more like a 4 series gear to take advantage.
    With 3.69's
    1st shifting at 6604 @ 45 mph
    2nd starts at 3544 rpms (graph doesn't go that low, but around 150hp) shift at 6300 (80mph_
    3rd starts at 4019 rpms (170ish hp) probably roll through the traps at 120 (450ish hp)
    Our transmissions are set-up for a broader TQ band, you may need to see if you gan change the internal gearing to a shorter gear to take full advantage of where your power is.
  8. #8 Re: people with dyno sheets
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    there is no way your curve came out that smooth. that has def has some massaging done to it.
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  9. #9 Re: people with dyno sheets
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    04 Comp G, L26, Ported Heads(stock vavles), Comp cams 130# vavle springs, XP cam, Cartuning Turbo T-66, Intercooled, 3" downpipe. 12.5 PSI
    Lumpy Gen 3
  10. #10 Re: people with dyno sheets
    Rockford, IL
    shawn, notice your AFR at the bottom of the sheet. kinda lean as well....some levels avove 12.0. with that much boost...you should see some knock, and that would show a dent in that graph up top. I have never seen a pull THAT smooth either......
  11. #11 Re: people with dyno sheets
    St Louis MO
    Thanks guys keep them coming. If you have access to others those would be great as long a partial mod list is available.
    2010 Camaro SS LS3
  12. #12 Re: people with dyno sheets
    Quote Originally Posted by Meemperor View Post
    Now that's what I'm talking about! I am looking for similar numbers, but peaking a shade earlier.
  13. #13 Re: people with dyno sheets
    Toronto, ON, Canada
    Quote Originally Posted by Ron Vogel View Post
    Wait until it's at 20+ psi in the spring. 13psi is winter mode.
    550whp is the goal I think, for the XP cam.
    PS. That's my buddies car (With my heads studs, Gaskets, valve springs, seals ... and a bunch of other stuff lol !)
    Lumpy Gen 3
  1. where are the MI people???
    By whitcomb in forum Midwest
    Last Post: 11-28-2011, 09:24 PM
  2. People who should know better
    By mlambert in forum The Rant Forum
    Last Post: 02-07-2008, 10:14 PM
  3. Dyno anyone?
    By SD GTP in forum Northeast
    Last Post: 01-12-2008, 02:09 PM
  4. 1HP Turbo Dyno Video
    By John02Hawk in forum Off Topic Discussion
    Last Post: 12-30-2007, 03:39 AM
