Thread: Possible Ignition control module problems?
Results 1 to 3 of 3
  1. #1 Possible Ignition control module problems?
    GT Level Member DWosik13's Avatar
    Detriot,MI
    Well i idle somewhat hard...enough to shake the engine a little
    when i go from 70-90 mph and get close to 4000 rpms it throws a random missfire code at no other time it does this any thoughts?
    2002 BLACK GTP ... R.I.P.
    New Car 2009 Cobalt SS
    http://www.cardomain.com/ride/3352208
  2. #2 Re: Possible Ignition control module problems?
    Nov 2008
    El Paso, Texas
    i had somewhat the same problem in my 01. Mine was throwing that misfire code when then engine went higher than 2000 rpm but nothing when it was lower or at idle. I was getting the misfire on cyl. 1 & 4, so I thought it was the coil, but the coil was good. I had the ignition module checked and it was good too. I changed plugs and wires but still got the code and a flashing SES when it reached that rpm. I had that rough idle too! What it turned out to be was that it needed to re-learn the CKP variation for the crankshaft sensor it uses to detect misfire. I used a MODIS scanner to do it. No more misfire and the idle definitely smoothed out.
  3. #3 Re: Possible Ignition control module problems?
    Apr 2008
    Chillin at the Beach , VA
    When my ICM was on it's way out, I was going through random stalling issues.
  1. Ignition switch problems
    By speedracer88 in forum General Tech Discussion
    Last Post: 01-18-2009, 08:39 AM
  2. Cruise Control Problems
    By DJFirestorm07 in forum General Tech Discussion
    Last Post: 12-11-2008, 02:01 PM
  3. Ignition Problems
    By iflycessnas05 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2008, 08:47 AM
