Thread: Car is puking oil
Results 1 to 7 of 7
  1. #1 Car is puking oil
    Oct 2014
    portland oregon
    Car started leaving nice size puddles off the front of the engine (pass side). I know I should clean it and see where its coming from but im to lazy.. strait up
    I unplugged the oil pressure sensor and its full of oil. Seemed to be a problem i have another one and im going to switch it out but could this be the culprit?
    Also should note that it reads o/p correctly
    thanks in advance
  2. #2 Re: Car is puking oil
    The factory sensor is more like a switch, it comes on with 5 psi of oil pressure.
    I'd swap it out, clean everything and start the car. Then see where it's coming from. The other place is the front cover seal on the balancer.
  3. #3 Re: Car is puking oil
    dont drive it till you swap it. it can really let go and you run out of oil. and well. bye bye.
    or just plug it with a brass npt plug. then it cant fail again. not like the sensor does a damn thing but leak.
  4. #4 Re: Car is puking oil
    Scotts method fixes the issue and if you ever got down to 5psi.. your motor is toasty anyhow. So you lose nothing but a leak.
  5. #5 Re: Car is puking oil
    Oct 2014
    portland oregon
    I swapped the switch/sensor and the leak is fixed. I would like to smack the p/o in the face the p/o for the way he did thing or had them done. there is a T fitting where the sensor is and another part attached to it that sends the signal to the gauge in the pillar pod. Here in the near future im going to pull that gauge and the extra crap off down there and plug it like scott unless it will cause a CEL.
  6. #6 Re: Car is puking oil
    so you have a oil/p gauge and the stock sensor still? plug the T its living in then. no cel will happen.
  7. #7 Re: Car is puking oil
    Oct 2014
    portland oregon
    Ok thanks. When I decommission the car here in a few weeks ill either pull the whole mess completely or take the thingamobobber for the o/p gauge and screw it in to where the sensor should be untill i get a boost gauge to put in the o/p gauge spot
  1. Puking coolant between the oil pan and transmission pan?
    By Fahrenheit in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-08-2016, 09:37 AM
