Thread: LIM gaskets
Results 1 to 14 of 14
  1. #1 LIM gaskets
    Oct 2015
    Qulin Missouri
    Hello all i have a 06 gp gt i smelled coolant and wouldn't you know it the dreaded lim gasket it looks like. Coolant is standing between the intake and the head.How hard of a job is this being supercharged and all? Thanks for any help! Oh by the way it has 104000 on the car as well.
  2. #2 Re: LIM gaskets
    its likely a coolant elbow that blow up on ya. look near the water pump, plastic elbow to the lim.
  3. #3 Re: LIM gaskets
    Oct 2015
    Qulin Missouri
    How can you tell? The intake where it meets the head all the way down from pass to drivers side is wet with Dexcool. I heard a hissing noise really close to the intake after it was run.
  4. #4 Re: LIM gaskets
    fill the rad with water, then start the car, watch the elbow for the leak. when the elbow blows up it blows coolant all over the place.
  5. #5 Re: LIM gaskets
    Oct 2015
    Qulin Missouri
    I checked them they are dry unfortunatly
  6. #6 Re: LIM gaskets
    split rad hose?
    the lim gaskets dont leak to the point of everything's wet. you got a 06 with upgraded gaskets already.
  7. #7 Re: LIM gaskets
    Oct 2015
    Qulin Missouri
    i don't see it leaking but it is wet on the intake.
  8. #8 Re: LIM gaskets
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    split rad hose?
    Not all 06 cars have the upgraded gaskets, early 06 cars built in 05 with engines built a month or two earlier still had plastic LIM gaskets.
  9. #9 Re: LIM gaskets
    post some pics or a vid then.
    the rad could have split too, the side tanks are plastic and its rather common for them to crack.
  10. #10 Re: LIM gaskets
    who cares bout that, either way you look at it, coolants not spraying all over from a lim gasket.
  11. #11 Re: LIM gaskets
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Took a min, but I found a horrible pic of an old fiero engine. My awesomely gigantic red arrows shows where the elbows are, which can be seen from the top.
  12. #12 Re: LIM gaskets
    Oct 2015
    Qulin Missouri
    Them stupid plastic elbows WERE cracked! I replaced them with the aluminum ones and the leak is gone! Thanks for all the help and advice!
  13. #13 Re: LIM gaskets
    GTP Level Member
    Oct 2014
    Once again Scotty nailed it! Nice work 06!
  14. #14 Re: LIM gaskets
    bazinga!
  1. Double SC gaskets, no gaskets, gaskets and RTV, what do?!? (Intercooler) Vac Leak
    By 01Blackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2014, 06:36 PM
  2. Gaskets
    By JerzNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2012, 05:45 PM
  3. gaskets!
    By IntenseFace in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2012, 07:11 AM
  4. Bad gaskets?
    By RichardL12 in forum General Tech Discussion
    Last Post: 02-01-2011, 02:13 PM
