Thread: 2004 Gtp tripped a bunch of codes after a full write tune
Results 1 to 8 of 8
  1. #1 2004 Gtp tripped a bunch of codes after a full write tune
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    It's a 2004 GTP that I tuned recently. It had a couple things wrong with it like a vacuum leak and a couple other codes. I tuned the pcm today and had to do a full write. I pulled the radio fuse before hand. Then after a while of driving 10 codes popped up.These are all the codes, p1518,p0030,p0201,p0202,p0203,p0203,p0204,p0205,p0 206,p0243,p0443,p1518.
    Could the tune have caused this or is there something else going on. The codes are 02 bank 1 low voltage, all of the injectors have low voltage. Then the other codes are for the bbv, evap, and throttle. And ideas guys?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: 2004 Gtp tripped a bunch of codes after a full write tune
    being it got codes after the fact, maybe. id try another flash. maybe a partial. or just put it on auto.
    best to build a off board for the 04 cars. the newest one listed in the how to section worked for me not to long ago.
  3. #3 Re: 2004 Gtp tripped a bunch of codes after a full write tune
    Apr 2014
    South Haven, MI
    Are 04+ cars just weird? It said it uploaded fine and I waited 20 seconds, popped in the radio fuse and started it up and let it idle. It was working fine. Then later on in the day I get a text telling me that the codes popped up and it won't idle for over 1 minute
  4. #4 Re: 2004 Gtp tripped a bunch of codes after a full write tune
    Kemmerer, Wyoming
    this is when having a wideband would be handy because I wonder what the afr is at idle.
  5. #5 Re: 2004 Gtp tripped a bunch of codes after a full write tune
    anythings possible with a dhp, they an be glitchy at times.
  6. #6 Re: 2004 Gtp tripped a bunch of codes after a full write tune
    tell the guy to look for a blown fuse maybe, the o2 evap and tb ate all listed codes there.
  7. #7 Re: 2004 Gtp tripped a bunch of codes after a full write tune
    Apr 2014
    South Haven, MI
    That's what I'm having him do. Apparently the ignition fuse can cause those kinds of issues
  8. #8 Re: 2004 Gtp tripped a bunch of codes after a full write tune
    Apr 2014
    South Haven, MI
    The issue was the tune. I got confused as to what systems he deleted like the EGR and EVAP systems.
  1. 2004 gtp 3.8 bottom swap- Needing a tune!!
    By jsgibbs1203 in forum PCM Tuning
    Last Post: 11-04-2015, 01:53 PM
  2. Full Write or Partial??
    By Iceman6669 in forum PCM Tuning
    Last Post: 09-04-2014, 06:01 PM
  3. Need tune 2004 gtp Near Saginaw Michigan
    By DrSnazzy in forum PCM Tuning
    Last Post: 04-03-2012, 11:45 AM
  4. 2004 Grand Prix Interior trim/color codes?
    By Damnir in forum General Tech Discussion
    Last Post: 03-05-2009, 09:10 PM
