Thread: Blue tooth Knock gauge questions
Results 1 to 15 of 15
  1. #1 Blue tooth Knock gauge questions
    Nov 2015
    WI
    I have been playing around with the blue tooth obd II and the torque app with the knock detector add in. Today it said i had 1 degree of timing. I have stock pulley, stock tune, stock manifolds, factory plugs, thrasher intake, u bent delete, high flow cat, slp exhaust non resonated. Coolant temp was 185 to 190 unsure of thermostat but think it has been lowered from factory. thinking 185.
    Should i be getting any knock with a stock pulley?
  2. #2 Re: Blue tooth Knock gauge questions
    and how much kr did it say at the time of one degree timing?
  3. #3 Re: Blue tooth Knock gauge questions
    Nov 2015
    WI
    Sorry i didnt explain well. the gauge reads KR so it had 1 KR. I assumed that was 1 degree of timing?
  4. #4 Re: Blue tooth Knock gauge questions
    no thats one degree of kr. lol
    kr cuts your timing back to keep the engine from blowing up.
    U bend delete is the only reason you have only one degree of kr too. with out it im sure you had up to 4 or 5 easy, but stock is fine like that.
  5. #5 Re: Blue tooth Knock gauge questions
    Nov 2015
    WI
    So just a intake and exhaust will get you 4 to 5 KR? Does stock have KR?
  6. #6 Re: Blue tooth Knock gauge questions
    Antioch, IL
    Stock has 5-8° kr
    the lower the number down to 0 is best. When modded 0 is needed
    2009 Challenger SRT8
    Expert at being gay.
  7. #7 Re: Blue tooth Knock gauge questions
    Quote Originally Posted by GTPNovak View Post
    stock tune and set up is up to 8º kr. tune is crap, the exhaust manifolds suck.
    the intake dont do a damn thing. neither does a cat back.
  8. #8 Re: Blue tooth Knock gauge questions
    Nov 2015
    WI
    Scott, i am confused. is my bluetooth gauge not reading correctly?
  9. #9 Re: Blue tooth Knock gauge questions
    Nov 2015
    WI
    for my set up u think i should be seeing 8 KR?
  10. #10 Re: Blue tooth Knock gauge questions
    its fine, 1 degree is nothing. stock cars can have any where from 2 to 8 or more tho. every cars different.
  11. #11 Re: Blue tooth Knock gauge questions
    Nov 2015
    WI
    so after the headers and tune do u think a 3.5 is safe?
  12. #12 Re: Blue tooth Knock gauge questions
    dont see why not. thats were most of us start out, or a 3.4 pulley.
  13. #13 Re: Blue tooth Knock gauge questions
    Antioch, IL
    I had AL104's, headers, open cone, 180 tstat and 3.4 with 0kr all day every day 3.5 is for girls
  14. #14 Re: Blue tooth Knock gauge questions
    Am I reading that you are using the knock detector plugin for torque? If so that is not what you want use to check for KR.
    • Open Torque
    • Go to Settings
    • Go to manage extra PIDs/Sensors
    • Click the 3 dots next to manage custom OBD2 PIDs
    • Add predefined set
    • Click Pontiac/GM/Opel/Vauxhall
    • Go back to the main page
    • Go to realtime Information
    • Click in a blank space
    • Add display
    • Add a gauge - I like the Half Dial meter as it shows you the highest and lowest values
    • Scroll down to knock retard
    • Done
  15. #15 Re: Blue tooth Knock gauge questions
    Nov 2015
    WI
    thanks for your help.
  1. Knock gauge installment help.
    By RyankendallGTP in forum Audio, Security & Visual Electronics
    Last Post: 10-23-2015, 04:16 PM
  2. Volume in car low when I use blue tooth
    By Timmaayy2121 in forum Introductions/Noob Questions
    Last Post: 01-22-2015, 03:35 PM
  3. SOLD
    By glanzergtx in forum For Sale - Parts
    Last Post: 10-26-2014, 09:22 PM
  4. Knock Questions
    By BigKev2403 in forum General Grand Prix Discussion
    Last Post: 03-12-2013, 10:05 PM
