Thread: car turns on and just dies out
Results 1 to 16 of 16
  1. #1 car turns on and just dies out
    Banned
    Feb 2009
    ashtabula, ohio
    Yesterday i replaced the fuel pump in 2000 gtp....we thought that was the problem but it wasnt.(330 dollars later...we figured out it wasnt)
    The car turns on for about 5-15 seconds and just dies out....any other ideas?
  2. #2 Re: car turns on and just dies out
    Oklahoma
    There could be many. Could be the fuel pressure regulator, could be the MAF, could be even the crankshaft position sensor. What would help would be listing any trouble codes you have (if any) and what if any troubleshooting steps and the results of that work you have done and so on. The more details we have the more we can help out.
  3. #3 Re: car turns on and just dies out
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    I bet it is the fuel pump resistor! You can find out if it is the issue for free by doing this:
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  4. #4 Re: car turns on and just dies out
    Oklahoma
    Crap, I keep forgetting about that part cause I dont have it, LOL. I agree, check that to start with.
  5. #5 Re: car turns on and just dies out
    Aug 2008
    KCMO
    will it stay running as long as you give it gas?
  6. #6 Re: car turns on and just dies out
    fuel pump regulator.
  7. #7 Re: car turns on and just dies out
    I live here. UR LOSN's Avatar
    Rockford, IL
    hook a fuel pressure gauge up to the rail and see if the pressure bleeds off.
  8. #8 Re: car turns on and just dies out
    Jan 2009
    hammond, IN
    i ahd the same prbel m with my car, i baught the cranks cahft sensor and that didnt do it and then i got the MAF that did the trick and since then have had no problems
  9. #9 Re: car turns on and just dies out
    SE Level Member kygtp's Avatar
    Oct 2008
    Cincy
    Mine did this same thing a while back, would run for about 5 to 10 sec then die out. If I gave it gas, it would barely run. Mine was a bad O2, replaced it, no problems.
    So I would have to say, MAF, or O2.
  10. #10 Re: car turns on and just dies out
    Aug 2008
    Long Island, New York
    could be your egr valve as well. i heard the if the valve is stuck open, on start it may start and die out
  11. #11 Re: car turns on and just dies out
    Aug 2008
    KCMO
    when mine did this is it ended up being the fuel pump speed control sensor
  12. #12 Re: car turns on and just dies out
    SE Level Member schreurs1's Avatar
    Dec 2008
    sioux falls, sd
    my guess would be MAF, O2, or something fuel delivery related other than the pump. easiest way is to watch the voltage reading with a scan tool or even better a graphing scanner.
  13. #13 Re: car turns on and just dies out
    Jackson, Ms
    I had the same problem. My car would run really bad for the first few minutes and finally smooth out. The problem turned out to be a short in the MAF circuit.
  14. #14 Re: car turns on and just dies out
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    my car had the same problem and it turned out to be the Fuel Pump+ Crank Sensor, but then my buddy's ended up being the MAF and all he did to test that was unplugged the MAF and i actually seemed to run better ans stay running that way ( as a temp fix of course)
  15. #15 Re: car turns on and just dies out
    Jan 2009
    hammond, IN
    ya the car runs great and drives really good. it onyl will do it sometimes and it has a new crank shadt sensor and MAF. those were al things that poped up and so then i fixed them all except the o2 so i was jsut wondering if that could be it and i will check that fuse right now, how do i know if its bad?
  16. #16 Re: car turns on and just dies out
    St. Louis
    to my believes if it is bad it usually sets off the SES light
  1. 2000 3.8 gp dies
    By redrivergar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-05-2008, 07:07 PM
  2. Tranny is in neutral during U-turns
    By Toofastgs in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-12-2008, 04:16 PM
  3. What wire turns on amp?
    By rtb in forum Audio, Security & Visual Electronics
    Last Post: 10-04-2008, 08:13 PM
  4. Power steering whine on left turns only...
    By bentendo92 in forum General Tech Discussion
    Last Post: 08-03-2008, 12:19 PM
  5. Car Dies out!???
    By letsndy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2008, 03:47 PM
