Thread: Topswapped gt overheating issue
Results 1 to 3 of 3
  1. #1 Topswapped gt overheating issue
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys i have a topswapped gt that runs great but i live in arizona have a 180 degree thermostat and am tuned for it. But during summer heat my temps have been getting up to the very top of the temp gauge right before red. Im wondering if this is normal or if maybe i need to upgrade from the stock gt radiator to a 1 inch gtp raidiator.
    Sent from my LG-H811 using Tapatalk
  2. #2 Re: Topswapped gt overheating issue
    check your temps via the obd port, the dash gauge is not all that accurate.
    as long as the fans are on you should be ok still.
    im running a na rad in my gs. its bottom swapped. my temps are the same as with the old rad. and i still run a 195 t stat.
  3. #3 Re: Topswapped gt overheating issue
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    I have the stock gt radiator in my car and a 180° thermostat temperature stayed the same after the topswap
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  1. overheating issue
    By gto421 in forum Introductions/Noob Questions
    Last Post: 10-18-2014, 06:42 PM
  2. Overheating issue! Help!!
    By mikegmoney in forum General Grand Prix Discussion
    Last Post: 08-09-2014, 03:13 PM
  3. Overheating issue
    By Below Average Joe in forum General Tech Discussion
    Last Post: 11-13-2011, 11:42 PM
  4. overheating issue
    By alreadytooken in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-29-2011, 10:28 PM
  5. overheating issue
    By doc7000 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2008, 01:18 AM
