Thread: Well this is bad... options?
Results 1 to 20 of 27
  1. #1 Well this is bad... options?
    Jun 2015
    Clearwater, FL
    Took my 02 GTP to the mechanic to see about diagnosing a bad knocking/metallic sound that I believed was the flexplate. Unfortunately I didn't have the time to inspect it myself as my schedule has been hectic.
    Mechanic called me this morning, he inspected the flexplate and found no damage to the flexplate but did discover that it is a bad main bearing in the rear of the motor. He said that he could pop the engine out, replace the bearing(s) and it would be fine for some time, but I should consider selling the car before any more serious issues arise ..
    My question is this: Is just replacing the bearings a dependable fix that will last, or just a Band-Aid until I can sell the car? What are your guys thoughts on this?
  2. #2 Re: Well this is bad... options?
    Kemmerer, Wyoming
    I would not recommend changing the bearings in the block. it would be more cost effective to find a used L36 block to swap in.
  3. #3 Re: Well this is bad... options?
    Jun 2015
    Clearwater, FL
    Aw **** :/ I'm trying to get this car together quickly for my brother so he has something to drive, take some pressure off of my mother .. I suppose I'll take a look around and see what I can find.
    Just curious, and so I can learn, why would just changing the bearings be a bad idea?
  4. #4 Re: Well this is bad... options?
    Because over time the mains turn into a oval shape and are no longer round, putting a new round bearing into an oval hole never works out too well.
  5. #5 Re: Well this is bad... options?
    SE Level Member b4black's Avatar
    Oswego, IL
    Your mechanic said to replace the bearing and then sell the car. That's a band aid. (and a crappy thing to do to someone).
    2002 Buick Regal GS - Intercooler, TOG headers w/ full 3" exhaust, 60# injectors, K&N cone, MPS 2.9, GMPP sway bars and STBs, 18"GXP wheels, 12" impala rotors, alternator hotwire, fuel pump hotwire, HPTuner newbie, Flex Fuel And 1982 Buick Regal GN & 1996 Dodge Ram Diesel 4x4 & Richard Petty's 43 JR Hemi Barracuda drag car
  6. #6 Re: Well this is bad... options?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Dancing Bear View Post
    Rebuild or replace. Changing just the bearings is just a band-aid that most likely won't stick for very long.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Well this is bad... options?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    A used L36 or even L26 block would need some modding in order to run properly, those are N/A blocks with higher compression ratios and the potential for serious problems without at least headers or a plog w/downpipe.
    If it's just to get him back and forth, find a JY car with a bad trans and an L67 supercharged motor. No additional mods required, and the block should be drop in and go.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  8. #8 Re: Well this is bad... options?
    Kemmerer, Wyoming
    All you would need to do for the l36 to run ok is a different tune if all you did was swap engine blocks. You could do headers or some type of ported exhaust manifold and it would help with flow which you would may or may not need.
  9. #9 Re: Well this is bad... options?
    Quincy, Mass
    Probably wouldn't be too hard to find an l67 but the l36 is plentiful
    No more GP 04 Impala SS Indy:
  10. #10 Re: Well this is bad... options?
    Oct 2014
    Frederick, MD
    The kr from a bottom swap without flow mods would be begging for uncle chip to visit.
  11. #11 Re: Well this is bad... options?
    Quincy, Mass
    Quote Originally Posted by WarStryker13 View Post
    With an l26 yes l36 not likely
  12. #12 Re: Well this is bad... options?
    Kemmerer, Wyoming
    I'm waiting for Scott to add his .02 cents
  13. #13 Re: Well this is bad... options?
    Oct 2014
    Frederick, MD
    He's done that already, hasn't he? Lol just realized that.
  14. #14 Re: Well this is bad... options?
    my 2 cents,,,, you guys got this one covered already lol
  15. #15 Re: Well this is bad... options?
    Oct 2014
    Frederick, MD
    I've got an L26, so my research has been lacking for the L36... It would still be a possibility, though.
  16. #16 Re: Well this is bad... options?
    they all can chip a piston. its the rods in the l26 that are supposed to be weaker.
    any top swap needs headers, or at least a plog dp combo. or uncle chip will show up and f up your weekend for ya.
  17. #17 Re: Well this is bad... options?
    Quincy, Mass
    No the l26 don't have the extra expansion on the piston rings so the expand from too much from boost and get stuck and pop.
    If you have the proper timing you should be fine. My rod bearings went on my l36 topswap with headers and an Intercooler because my tune wasn't right and I laid into from a dead stop.
  18. #18 Re: Well this is bad... options?
    Oct 2014
    Frederick, MD
    That's funny, because the press release for the 04 GP states that the forged powdered metal connecting rods are stronger than the previous generation's. Lol
  19. #19 Re: Well this is bad... options?
    Kemmerer, Wyoming
    that is absolutely true with exception, the L32 has the strongest rods between all series 2 and 3 engines.
  20. #20 Re: Well this is bad... options?
    Oct 2014
    Frederick, MD
    So are the pushrods weaker? Because I've heard from almost everyone on here that the "rods" in the series 3 are weaker...
  1. Options for ZZP 1.0 PCM
    By M7x350z in forum General Tech Discussion
    Last Post: 04-19-2014, 04:38 PM
  2. H/U options
    By BLWNPontiacs in forum Audio, Security & Visual Electronics
    Last Post: 09-28-2011, 09:40 PM
  3. Rad Options.
    By matt5112 in forum General Tech Discussion
    Last Post: 07-28-2011, 10:15 AM
  4. TB and MAF Options ?
    By Lawngoose in forum General Tech Discussion
    Last Post: 08-23-2010, 07:59 PM
  5. 2 options.
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 03-27-2010, 12:27 AM
