... as a normally aspirated 3800?
I have an 02 Ssei. I need one haha, anyone have an extra sitting around gathering dust?
Do you need a supercharged balancer or a n/a balancer?
Thanks Scotty, I will scope out eBay.
There's a def vibration in the engine.
Fresh plugs and wires made no difference. I checked the converter vbolts and for flex plAte stress and everything was good there.
All the idler pullies are good, including the power steering.
From what I've read it sounds like a failing balancer.
look at it from the wheel well, wheel off lift the splash shield if its cracked, you'll see a crack around the whole balancer where the rubber meets the metal part the belts run on, some times you see them wobble around at idle.
