Thread: GTP Slow acceleration
Results 1 to 4 of 4
  1. #1 GTP Slow acceleration
    Jun 2016
    WI
    I have a 1999 grand prix GTP, I hit the gas and the car drives but I am at 5 on the rpm gauge and it will slowly start to roll and continue to roll until i let off, I don't want to push it or over work the engine, but I also don't want to take it to a garage and get screwed either. So any help as to where to start or what to argue with the mechanic with later would be much appreciated. Thank you.
  2. #2 Re: GTP Slow acceleration
    St. Louis
    How's the trans. fluid level look? Color of the fluid? Almost sounds like the trans is slipping bad.
  3. #3 Re: GTP Slow acceleration
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    http://www.tripleedgeperformance.com...ward-Cold.html
    This sound familiar?
    I had the same thing happen, but my cheap fix was fluid & filter, attempt to drive it for at least 100 miles, Fluid and filter again with 2 bottles of Lucas. Be sure to adjust the amount of fluid you are putting in with the amount of additives, don't overfill it or bad things happen. If that doesn't do it, parts inside the trans need replaced.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  4. #4 Re: GTP Slow acceleration
    Jun 2016
    WI
    Drove it the next day to get it checked out and everything drove like nothing happened when I went to the mechanic, So they just told me to give them a call when something happens. So drove it home, but it takes forever to shift out of 2nd then when it does it spikes up and then hits 3rd, and again takes awhile to get into 4th but it just goes into 4th when needed. Maybe something electrical? or the transmission is going?
  1. Slow acceleration or no acceleration
    By tierzu in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-30-2015, 01:05 AM
  2. Slow Acceleration when engine is cold from idle
    By dblisle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2012, 11:30 AM
  3. Rpms drop under slow acceleration at 45mph
    By Bluemagic in forum General Tech Discussion
    Last Post: 04-29-2012, 07:31 PM
  4. Slow Acceleration 3800 Series III in Fiero
    By D2inDFW in forum PCM Tuning
    Last Post: 03-27-2009, 11:37 PM
  5. 98 grand prix slow acceleration
    By jeffster in forum General Tech Discussion
    Last Post: 03-27-2009, 05:15 AM
