Thread: What kind of Springs should i get?
Results 1 to 6 of 6
  1. #1 What kind of Springs should i get?
    Sep 2015
    Denver
    So im trying to figure out if i should upgrade the springs when i do my rocker install on my 2002 Gtp. Right now i have a set of 1.8 yella terra rockers waiting to go in, and currently would like to stay where im shifting which is about 6200 Rpm. My main concern is wearing out the timing chain dampener since its my daily driver right now. Has about 130K on it. What would you guys recommend i do?
  2. #2 Re: What kind of Springs should i get?
    Kemmerer, Wyoming
    either 90's or 105's
  3. #3 Re: What kind of Springs should i get?
    Sep 2015
    Denver
    im looking at the blue 90's on intense. would i need anything else to run with them like manely retainers? are they very hard on a dampener?
  4. #4 Re: What kind of Springs should i get?
    Kemmerer, Wyoming
    you need new LS style retainers, valve seals, and locks. I ran 90lb springs for about a year with my xp cam revving it to 6200 without an issue. you will also need new valve cover gaskets and rocker arm bolts unless the rocker kit came with them. personally, I wouldn't mess with the timing chain dampner unless you suspect it of failure. the oem one should be fine. I did 1.9 ratio rockers on my last grand prix and thought it was ok. I wouldn't mess with the 1.8's unless you got a really good deal on them or if you think you might do a cam in the future because you can measure for the correct length pushrod when the cam is in and do an xp cam with 1.8's and the right length pushrod.
  5. #5 Re: What kind of Springs should i get?
    Sep 2015
    Denver
    Quote Originally Posted by SgtMarshal View Post
    Thanks for the good advice. I currently have a set of 1.8's only because i got a good deal on them. I would love to do a cam in the near future but that would most likely be this coming winter. Still need to figure out emissions if i decide to go that route. Also have bolts and pushrods for the rockers too. Its whatever comes with the yella terra sets.
  6. #6 Re: What kind of Springs should i get?
    Kemmerer, Wyoming
    A cam doesn't really effect emissions
  1. Has anything put nos on there car if so what kind.?
    By nance in forum 5.3L V8 (LS4)
    Last Post: 07-01-2015, 07:34 AM
  2. What needs done to remove Lowering Springs and go back to stock springs?
    By NotEnoughGPs in forum Brakes/Suspension/Chassis
    Last Post: 05-19-2015, 09:49 PM
  3. are these springs the blue ls6 springs people are talking about?
    By vikesfan in forum General Tech Discussion
    Last Post: 03-15-2015, 11:10 PM
  4. Replies: 39
    Last Post: 02-04-2013, 10:42 AM
  5. One of a kind '02
    By RegorHtims in forum Off Topic Discussion
    Last Post: 03-30-2011, 11:52 PM
