Thread: Interesting (old) article I found
Results 1 to 3 of 3
  1. #1 Interesting (old) article I found
    Apr 2015
    West Des Moines
    http://www.kennebell.net/KBWebsite/T...NFORCEMENT.pdf
    Found this and didn't know if anyone had seen it before. I know it's about a mustang but its about the Gen 3 M90. If anyone is into tech numbers and data check it out. I'm surprised the cranked it out to 20k rpm!
  2. #2 Re: Interesting (old) article I found
    Kemmerer, Wyoming
    it makes you wonder why GM went with Eaton and not Autorotor
  3. #3 Re: Interesting (old) article I found
    GXP Level Member
    Mar 2015
    Tomball
    Finally, I saw this at work yesterday then I couldn't find it again. I remember this article when it came out. There's a lot of good information there it was also one of the first articles that actually was about as close to apples to apples comparison of a Roots and a Lysholm supercharger. The M90 used for all the kits back then from Roush, Allen and the others used the 94-95 Tbird SC supercharger. The reason that GM didn't use a Lysholm was cost. The complexity of machining Lysholm rotors back when these were new was very high. Rotors for the Eaton had already been developed a long time prior and the mass production of the Eaton superchargers for Ford. Eaton didn't really need to do much to make a supercharger for GM other than make new castings for the case and snout. This would have been way more cost effective to do rather than having to develop a and have a company retool for the numbers needed. Eaton could easily fill that volume as they had already been doing it for many years.
    Jeff
  1. Found this interesting car in the junkyard.
    By charlie31603 in forum Off Topic Discussion
    Last Post: 11-15-2012, 07:44 AM
  2. Found this article interesting and then laughed at the error they made
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 05-21-2010, 05:36 AM
  3. Interesting Article Describing Water/Methanol Injection
    By rynoman03 in forum General Tech Discussion
    Last Post: 02-19-2010, 07:36 AM
  4. Interesting article
    By Bogers99GTP in forum Off Topic Discussion
    Last Post: 01-21-2009, 08:06 PM
  5. Interesting article on Traffic and Driving
    Last Post: 07-08-2008, 10:07 PM
